![]() | Home > Puma (Tdci) > N Type tow electrics |
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 ![]() ![]() |
Are the N type tow electrics plug and play or plug and pay dealer to activate ?
Simon |
Thanks
MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2681 ![]() ![]() ![]() |
Yup, as bpman says, get the correct LR Part (number LR005920), and it just plugs in to the car. All the electronics work straight away (such as the dashboard light shaped like a green trailer telling you the indicator on the trailer is working).
Up under the drivers side rear wheel, right at the back, above the crossmember (on a 110, best to lie on the ground with your head behind the back wheel) there's a feeble plastic flap with 2 screws - the connector is under there. Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336 ![]() ![]() ![]() |
if you do get a new one take some time to waterproof it when you fit it - I used vaseline on all the pins/connectors. My original had corroded badly, the wires were all black so rewired using marine grade cable. Should hopefully stem corrosion for a while.
Thanks..
My 130 not due until March but accumulating a pile of parts for it. Simon |
I meant to add, the genuine ones have gloopy silicone sealant over the socket end but I managed to take the other end apart and fed the wires through the rear of the x-member.
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752 ![]() ![]() ![]() |
?? Funny,, all mine i have fitted, the plug when through the X member hole ok ?? no need to take apart ![]() Main Brian James Trailer Dealer for South West UK |
Tim, you must have some bigger holes in your rear x-member or simply more talented than me at hole manipulation ![]() |
