Home > Puma (Tdci) > diff whining.. and noise when i lift off
Stacey007
Hello
Just been away in the Puma and it was loaded to the hilt Smile I don't use it much these days and noticed the diff is making more noise around 2 years ago.
Its definitely whining more and when I'm under power and lift off its sort of a 'screeching' sound (hard to explain not high pitched but a noise...)
My Question...
Is it worth getting a reconditioned Diff fitted now? or upgraded one? (cars on 106K now)
Is it likely to be the front diff or rear / or both?
I did just search my e-mails and did inquire about Ashcroft diffs 2 years ago...
Advice welcome, or will it just carry on....
Post #960286 2nd Aug 2022 11:03am
geobloke
Hi Stacey007. Are you absolutely sure it is the diff and not the wheel bearings? It'd be a tad irritating if it were wheel bearings and you had forked out for two new diffs.
You could try taking the rear pro-shaft off and seeing/hearing if that changes the noise.
Noises like this are always a pain to pin down... could even be your transfer box for example.
Post #960288 2nd Aug 2022 11:39am
jst
try with props off, screeching could just be a UJ or wheel bearing as suggested above.
screaching is unsual for puma diff failure, a rumble yes in which case rear diff. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #960291 2nd Aug 2022 12:20pm
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
In my experience, the short nose rear diffs on a 110 tend to sound like an old tram when they begin to wear, a bit rumbly under load then with a whine when coasting/over run.
First port of call for me would be to drop the oil from the diff and see if it's full of filings.
Chris
Post #960295 2nd Aug 2022 1:18pm
Stacey007
Some good advice.
I will see if I can get it checked, your right not having to spend on new diff(s) would be a bonus.
Post #960360 2nd Aug 2022 8:26pm
htb2
Wales
Just changed my rear one at 250K, grumbling on drive and whining on over run.
05 TD5 with short nose diff.
Post #960368 2nd Aug 2022 10:01pm
