![]() | Home > In Car Electronics > Central locking / electrical fault |
Gasket Member Since: 30 May 2020 Location: Manchester Posts: 629 ![]() |
Can't help with the wiring mod but re: the 10AS thing just look to a company like technozen.
https://www.technozen-electronics.co.uk/la...-services/ Basically the base 10AS ECU spec did not come with the relays necessary to power the central locking. You remove your ECU post to Paul at Technozen and he'll add them back in to the spec that yours should be. I'm about to do this on mine as I'm retrofitting factory CL. As your ECU isn't the original it might be worth Paul checking that all the alarm/immobiliser bits are activated too. Pretty painless and only costs about £50. Give him a call, he's a nice lad. EDIT: see you've already had an electrician have a go. Might be worth calling Paul in case there's something else that needs switched on. Failing that its out with the test lamp to find the fault. I can't see a green 10AS in your pics unless I'm missing something. Orange and pink wires control the CL actuators - someone more knowledgeable will be along shortly but the cut orange wire might be your issue. |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 398 ![]() ![]() ![]() |
The nasty blue and red repair is for electric windows, they break for a past time.
The wires going to the CDL motors in the door are pink and yellow and will lead directly to the 10AS box behind the dash. If you google 'Land Rover Defender Td5 2002 wiring diagram' you will find several results linking you to a PDF version The silver box could be some sort of power boost chip thingy? A tracker maybe? Does it say anything on it? Where do the wires go? ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Poulstonb Member Since: 30 Jun 2022 Location: Styal Posts: 88 ![]() ![]() |
The silver box has no writing on it , a power chip is possible as the car does seem to have more power than others I’ve previously driven.
It has 3 wires one goes to ground one to the what I think is ecu and other I can’t trace. |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2762 ![]() ![]() |
I’m pretty sure that the 10AS has to be programmed to enable central locking, just adding the relays to the board is not enough. If the one in yours came from a base spec vehicle without central locking then the function will not be turned on in the software.
Thanks
Module sent to Paul so fingers crossed for a positive outcome |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 677 ![]() ![]() ![]() |
Silver box is probably a a boost box to cheat the engine ECU from overboost - look here: https://www.paddockspares.com/turbo-boost-box-td5.html "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
Yes it looks just like that .
Evening all
So managed to get the 10AS module repaired by technos , amazing service !!!!! Front doors are now working on the locking fob but the rear door makes a noise but dosent function . Should the rear door lock / unlock with the central locking TIA |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2468 ![]() ![]() |
Yes, as per wiring diagrams above.
Sounds like the rear CDL actuator is struggling to move the mechanism. This could be a High resistance wiring connection, stiff mechanism or weak actuator. Remove the rear door card, oil the mechanism and check electrical connections to actuator as a first step. Noting that the wiring between the door and the body can fracture so may be damaged but not broken. |
