Home > Maintenance & Modifications > I think I made a mess, need help with Lights
Page 2 of 2 <12
LR90XS2011
Looks Smart DEFENDER 90 TDCI XS,
Post #960016 30th Jul 2022 7:19am
Mo Murphy
You don't get fog in America ? Amazing 😊
50 Shades of Pennine Grey
Post #960035 30th Jul 2022 2:12pm
Soulrider911
United States 1989 Defender 90 2.5 TD SW Chawton White
Decided, ya gotta have the red fog Smile
 1989 Defender 90
2022 Defender 110 SE
DIY’er | Always learning
Post #960048 30th Jul 2022 8:12pm
Soulrider911
So more discoveries. The ground junction in thr left rear was total garbage. Removing the ground was fun Very Happy , needed 2 people as the nut is under in the wheel well. Cleaned it up, sanded the contact point and added a custom harness for grounds.
 1989 Defender 90
Post #960058 30th Jul 2022 10:23pm
Bowbearer
United Kingdom 1985 Defender 110 200 Tdi SW Auto Baltic Blue
I went through the same nightmare, ended up with a new rear loom!
You can get an indicator warning bulb with a resistor, as the bulb allows current to run through it.
I dont understand either but it works. you can buy them on ebay.
The other thing is to check your hazzard warning switch. if it is slightly faulty it will cause problems. pay for a good one, the one i first bought was faulty and i spent days trying to suss the problem.
All fixed on mine now.
Good luck,
Like the Pig.
Post #961413 12th Aug 2022 11:43am
Soulrider911
Oh wow. Lucky for me it was just my left rear corner. Once I fixed those grounds all the lights worked great.
I also did order the “earth fix” for the dash indicator light. I pulled out the indicator bulb for the time being, ground fix which just arrived yesterday!
So all has been resolved thankfully.
I also found some nice led headlights. Lastly, put on an led bumper, made some custom
Wire looms and wired it all up!! Now I have daytime running lights and the bumper leds are on a rocker switch that is wired to a relay… so if I forget to turn them off they turn off with the ACC.
Was a fun project
 1989 Defender 90
Post #961430 12th Aug 2022 3:48pm
Bowbearer
Nice one.
I got interference on the radio when I put my led headlights on. I put those ferrous tubes on the wire ring and solved the problem.
Enjoy your truck it looks well.
Post #961431 12th Aug 2022 4:08pm
Soulrider911
By ferocious tubes do you mean resistors?
These?
 1989 Defender 90
Post #961433 12th Aug 2022 4:27pm
Bowbearer
No sorry, my bad.
Ferrite core clip on.
Simply clip on to lighting wires.
Post #961438 12th Aug 2022 4:35pm
Page 2 of 2 <12
