Home > In Car Electronics > TD5 rear washer jet button
phillips321
2005 Defender 110 2.5 TD DCPU Belize Green
Can anyone let me know which wire behind the switches is the correct one to control the rear washer jet pump please. What colour/location in the dash is it?
I plan on using this for controlling a relay instead and have the replacement switch already.
Thanks in advance.
Post #959272 23rd Jul 2022 1:40pm
freddie206
United Kingdom 2006 Defender 110 Td5 HT Belize Green
Post #959285 23rd Jul 2022 3:51pm
phillips321
Perfect. Exactly what I was after. Many thanks
Post #959286 23rd Jul 2022 4:16pm
phillips321
freddie206 wrote:
Should be what you're looking for...
https://www.lrworkshop.com/connectors/defender-2002my/C0073
Next question if I may.
Any idea how I can release these metal connectors from the plug? I assume a drawing pin but I can’t figure out how. Thanks
Post #959309 23rd Jul 2022 7:57pm
phillips321
Ok have figured out how to release the metal bits from the plug. For those wondering come in from the front with a long drawing pin and lift up whilst also pulling the wire out from the rear. See photo.
Now on to my next question. How can I have the button glow when driving lights are on? And how can I have the little red led glow when the switch is activated (latched).
Thanks everyone.
Post #959313 23rd Jul 2022 8:22pm
freddie206
As long as you’ve got the correct donor latching switch and follow the wiring diagram below you should be good…
https://cdn.accentuate.io/6660232904789/11...419280.pdf
Post #959338 24th Jul 2022 9:04am
phillips321
Well In Freddie. Exactly what I needed. Take an internet kiss and pint from me.
Post #959350 24th Jul 2022 11:08am
