Home > Puma (Tdci) > RPM not working, Temp Gauge at max, loss off engine power
DeCA
Belgium 2007 Defender 90 Puma 2.4 SW Barolo Black
Hi There, problems in my dashboard and loss and lack /loss of power, due to gauge meters that not working properly, I cannot find a solution. I installed a winch, perhaps wrong???
Puma 2.4, 2007MY
Post #959112 21st Jul 2022 4:25pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Maybe check your electrical connections first? Such as battery terminals and whatever you have touched during installation? Bad/loose connections could cause ECU confusion.
Post #959126 21st Jul 2022 5:42pm
Ianh
As above it does seam a battery connection issue.
When installing your winch have you added an additional negative to your negative battery terminal clamp ?
If so it will likely be preventing the clamp gripping the negative terminal correctly and this could be your problem.
There is an easy fix for this if that’s the issue.
Post #959130 21st Jul 2022 5:52pm
