Home > Wheels & Tyres > Stock Series 3 max wheel / tire sizes without rubbing
slowisthenewfast
United States 1988 Defender 110 2.5 TD CSW Chawton White
Hey all,
I've been diving through all kinds of different threads in here but am still a little foggy. I'm curious for a Series 3 without a lift or body mods, what sort of wheel / tire options and combos work best without causing rub and what sizes max out the stock setup?
I'm basically between the Wolf wheels with their -20mm offset and these 8x16 deepset steel wheels with 0 offset. ( https://www.nakatanenga.de/en/vehicle-equi...&c=299 )
My big question is if you were to run 8x16 wheels without offset, would you get rub with fatter tires like a 265 or 285/75r16? Also for height, can you run a 255/85r16 comfortably or does it look goofy maxing out the wings? Also toying with different tires, like goodyear wranglers, bfg km3, or cooper discoverers, but curious to hear what other combos people have been using and liking.
Thanks!
Post #958651 17th Jul 2022 7:57pm
slowisthenewfast
Actually come to think of it, i need a masterclass on wheels and tires haha. Does anyone have a good existing thread they have found comprehensive?
Post #958663 17th Jul 2022 9:37pm
Oldowner
Anything wider than 750-16 makes the steering too heavy and puts undue strain on the lower steering column.
750-16 on Wolfs is a good combination but you definitely need extended wheel studs on a Series 3.
Post #958691 18th Jul 2022 8:48am
One-Tons ran on 9.00x16 tyres and did not have PAS.
Post #958698 18th Jul 2022 10:22am
Grouse
Fwiw I have run 265’s on a LR without PAS and it is fine as long as you don’t try to steer with the vehicle stationary. They do work just bear in mind the vehicle needs to be moving to steer
Post #958741 18th Jul 2022 4:34pm
Oldowner
That is because they had a lower ratio steering box Rolling Eyes Rolling Eyes
Post #958794 19th Jul 2022 8:02am
Interesting, I didn't know that!
Post #958840 19th Jul 2022 1:59pm
camelman
I ran 33x10.50s on my s3 lightweight for a few years with no problem (other than needing 6 inch wider arches) Whistle
Post #958843 19th Jul 2022 2:15pm
