![]() | Home > In Car Electronics > 2004 TD5 electrical short |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 605 ![]() ![]() ![]() |
Do you have this issue if the headlights are off?
Does the alarm/immobilizer work correctly and is the immobilizer enabled (Only allows car to start with transponder on the keyring?) |
Reivilo Member Since: 03 Jul 2022 Location: Bredasdorp, Western Cape Posts: 8 ![]() ![]() |
The TD5 assemblies in South Africa came out quite basic - no immobiliser, alarm, heated seats/windows or electric windows.
So to answer your question: there is no horn when the headlights or park lights are turned off. And the horn does not go off automatically and imediatly if I turn the lights on, only after some time when I traverse over bumpy or badly corrugated gravel road. Typically the same as when a lightswitch makes a bed lamp flicker due to poor contacts. I haven't had too much of a problem on tarmac as yet. I did not start fiddling with the suspect wires yet... laziness! |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 385 ![]() ![]() ![]() |
The front left headlamp and LH horn share an earth path, there is a splice joint in the loom before that circuit along with the alarm sounders (where fitted) and windscreen washers combine into a single earth that is part of the wing wiring harness. There is a grey plug near the heater/bower assembly, these circuits are earthed on pin 3, see pic below. Seeing as you say the horn is affected but nothing else I'd be inclined to reveal the wires in the loom near the headlight and check that there is no damage on the earth cable. Rig up a circuit tester so that the earth terminal in the headlight connecter and a good route to earth show a circuit. Then give the wires a wiggle and see if you can interrupt that earth.
![]() Click image to enlarge ![]() Click image to enlarge |
