![]() | Home > Puma (Tdci) > Recommendations for live data display? |
steveww Member Since: 05 Jan 2022 Location: Malton Posts: 611 ![]() ![]() ![]() |
Build your own
![]() https://www.adafruit.com/product/4759 Alternatively Ultragauge and Scangauge are the usual suspects available from eBay et al. |
Polarismd Member Since: 13 Feb 2022 Location: Leicestershire Posts: 64 ![]() ![]() |
Ta, I went with a thing from Nexus (bluetooth) and a right angled cable adapter.
Amazon so can return easily if it doesn't work! Chris |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3411 ![]() ![]() |
Try the 'torque' app and a cheap bluetooth obd sender for £10. Works a treat
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 982 ![]() ![]() |
I have a Torque app. Not much data comes out of the OBP. No oil temp or pressure. Boost, voltage and water temp are displayed though. I was told that LR just don't present them so can't be seen.
Peter |
Hi,
I went with car scanner pro. I am getting all the information I need. |
Hi,
Can I ask what that is?
Hi,
The only things I am missing now are oil temp and oil pressure. Chris |
