Home > Puma (Tdci) > Screeching coming from engine bay |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 633 |
Unfortunately it could be anything - could you take a video and post it? Any incline of what area it’s coming from? 2008 2.4 110 Utility XS.
7th Jul 2022 8:48pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5428 |
Check for soot around the exhaust manifold / turbo area. Other than that, check hoses to intercooler are all seated properly.
7th Jul 2022 8:50pm |
chrisc2306 Member Since: 02 Jan 2020 Location: Glasgow Posts: 58 |
It’s really hard to tell, more from the back end of the engine towards the cab it sounds like. Would a dodgy injector seal make a screeching sound?
7th Jul 2022 8:51pm |
No I don’t think so. Loose injectors cause a knock.
7th Jul 2022 9:11pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16935 |
A screech is usually a split pipe to or from the intercooler, a loose exhaust manifold, or a leak between the manifold flange and the turbo.
7th Jul 2022 11:55pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3623 |
Did you change the inlet manifold elbow to silicon? These are a pig to even see, let alone fit so you might not have it seated right. Are you getting an engine management light on the dash?
8th Jul 2022 6:17am |
landhank Member Since: 27 Oct 2021 Location: RLP Posts: 37 |
You wrote that you put in a EGR blanking plate... That could be the reason for that noise, too. Check if the gaskets are sitting 100% correct and if everything is fine in that area.
8th Jul 2022 6:22am |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1874 |
Does it happen under load? if you used the BAS intercooler hose's they can wear on the pulley and on the steering arm if not fully seated..... i found out the hard way! 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
8th Jul 2022 7:12am |
Doc P Member Since: 03 Apr 2016 Location: Midlands Posts: 565 |
Serpentine belt tensioner pulley bearings? Mine did this - screech at 2300 rpm - really annoying. Lubed the pulley wheel bearings and eventually it went away but it didn’t work straight away. Took care not to get the lube on the belt or it’s contact area on the pulleys.
8th Jul 2022 10:55pm |
Big Harold Member Since: 09 Jul 2018 Location: nsw Posts: 71 |
If you have dislodged something while doing the injectors and it has found its way to the turbo and damaged the vanes this will make a noise under boost usually worse when cold.
Or oil injection nozzle to turbo bearings clogged will also cause noise. I have replaced 2 turbos at around 100K KM because of this issue. Mark |
9th Jul 2022 12:42am |
Thanks for all the replies it turns out that the egr blank just wasn’t completely seated right and that’s what was making it screech, it’s nice and quiet now
9th Jul 2022 1:28pm |
