![]() | Home > General & Technical (L663) > Wireless Apple CarPlay / Android |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2763 ![]() ![]() |
If you’ve used CarPlay for navigation (via Google maps or apple maps etc.) then pressing the navigation Home Screen tile will take you back into that rather than into the built in app.
Open the main apps menu and choose navigation to open the built-in satnav. If you set a route it will then appear on the home screen tile again, with the directions info etc. as well as in the instrument display (if enabled). |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1448 ![]() ![]() ![]() |
Yes this stumped me when I first set it up and I worked it out by pressing every button until I found the right one
![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
whiterdesign Member Since: 10 Jun 2021 Location: Preston Posts: 281 ![]() ![]() |
Thanks for that will try tomorrow 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3493 ![]() ![]() |
Currently don’t have CarPlay set up on mine, been trying the Pivi system. It’s working well maybe not as slick. 24MY 90 D250 HSE, Tasman Blue
Retroanaconda, tried what you said but when I press the navigation app it just takes me back to google maps, which I was using on CarPlay, what am I doing wrong 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
If you press the navigation tile on the Home Screen it will do that, you have to go into the apps menu (bottom right button) and then choose navigation from the array of options.
Select navigation from this menu (LHD shown so will be reversed for RHD): ![]() Click image to enlarge |
Ok thanks will try again 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
Thanks Retroanaconda that worked. Much appreciated. 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
