Home > Puma (Tdci) > Timing Chain snapped
Page 3 of 4 <1234>
Co1
From memory, the oil pump means taking the sump off as well, so you will need sump gaskets as well. I recall that the sump is very prone to bending/warping when you take it off, so it might be worth having one on hand that you can return if not needed.
Post #956872 30th Jun 2022 6:11am
Dinnu
I am still trying to get my head around how a seized oil pump can snap the timing chain. Are they not 2 separate chains running on different sprockets from the crank? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #956873 30th Jun 2022 6:26am
Wethering Landy
United Kingdom 2011 Defender 110 Puma 2.4 USW Santorini Black
Thanks for the replies. From my understanding, the pump becomes partially seized and this puts strain on the cam chain. The cam chain being bigger take the hit.
I am not sure if the pump is worn out of not - its just I have the whole lot off and so might as well do it now.
I guess a new sump tank and gaskets is added to the shopping list!
Post #956879 30th Jun 2022 10:15am
Naks
Wethering Landy wrote:
...Thanks Naks and also Phil McGee at Engine 710 for this golden news! If I could buy you both a beer I would!...
Glad you got the relevant info Thumbs Up
If I'm ever visiting Phill in Scotland, we'll hold you to it Rolling with laughter --
Post #957394 5th Jul 2022 8:34pm
Wethering Landy
Hi friends
OK, the chain is on - but I have hit a snag and need your advice (again!).
The top clamp that holds the lifters on top of the valves is held down by 10 M6 bolts. On tightening them up I snapped one!
Have a look at the attached. It is the middle one on the inlet side.
What should I do? Leave it out? Drill and Tap again?
Taking the head off for this seems extreme.
I put lock tight on the others. They all seem tight.
Thanks
Post #957648 7th Jul 2022 9:15pm
Wethering Landy
I hope you can see the image here...
Post #957649 7th Jul 2022 9:18pm
Co1
I’d have a go at getting it out. Have you got a set of easy outs, if so start there before going the whole jog and drilling out and re tapping. Take your time and make sure you are drilling central.
Post #957650 7th Jul 2022 9:18pm
Co1
Can see that. Definitely need to sort it I think.
Post #957652 7th Jul 2022 9:21pm
The Zee
If you can find a set of reverse flute drills (cut in reverse) as you drill the force of drilling might start to remove the remains of the bolt as the drill bites.
Good luck Zaid-M
www.DefencePhotos.com
Post #957654 7th Jul 2022 9:55pm
Wethering Landy
Thanks for the advice. I tried and tried. But I can't get it out. I have added a bit of thread lock to the others and so time will tell if this will be a problem.
Post #957749 9th Jul 2022 7:37am
Wethering Landy
So on a separate note: Now that I am ready to start the engine - what do I do?
I haven't technically run out of fuel - but there will be air in the system.
Do I crack the inlet nut and turn the engine until diesel comes through? The last engine I bled was a Fordson Major tractor and that was relatively simple - as per above.
Advice please - and if complicated perhaps a step by step guide.
Post #957750 9th Jul 2022 7:40am
Wethering Landy
OK - final update. I got it started and it sounds like a new engine!
I put this down to the fact I cleaned out the inlet manifold at the same time as taking the rocker cover off.
2 of the injectors were not working either so I am surprised it was even running.
Please can I thank everyone who has offered advice. Without this forum I would not have been able to do it. I certainly saved LOADS of time finding out that the Puma 2.4 Tdci is a non-interference engine - and I hope this thread becomes helpful to others in the future.
Best wishes
Post #957901 11th Jul 2022 3:07pm
BrickBox
Fantastic news! Thankfully a lot cheaper than what you originally thought also. 2017 5.0 V8 Supercharged RRS SVR
2008 2.4 110 Utility Station Wagon XS.
Post #957908 11th Jul 2022 3:42pm
Wethering Landy
Hi friends
Thanks
Dear Friends
It would seem that after a summer of driving - the bolts may have worked loose that secure the top clamp that bears down on the lifters.
It is making a mother and father of knocking noise and it is coming from the rocker cover.
I have checked the injector clamps and they are tight.
Thinking back, I think I over tightened all of them and this is why they have come loose or shredded the threads completely.
To be totally honest with you - looking back - I f****d it up as I borrowed a torque wrench and had the incorrect setting on it. After winding for what seemed ages on each nut in sequence, it dawned on me that I had made a major Bo Bo as none were going tight. I expect the threads at this point were Censored .
So I put them all in with locktite and have hoped for best since. It seems that now it has come back to bite!
Does anyone have a solution to this other than replace the head which is a major job? Has anyone used Helicoils on this job? Will they be strong enough?
Or is there a more robust solution?
In my mind - I think it will work but as I have one bolt snapped - it might be the issue rather than the other 9 held with locktite.
You thoughts would be grateful
PS I did try easy-outs on the snapped bolt but I could not get it out. Is there another solution? Drill another hole in the clamp?
Post #975903 28th Dec 2022 8:08pm
Helicoils will, if fitted correctly, be stronger than the parent alloy, but you will need to sort out the sheared bolt. I think that the part with damaged threads is the camshaft carrier rather than the head, but think it would probably be inadvisable to drill, tap, and Helicoil this with it in situ on the engine due to the likelihood of swarf entering the sump and lubrication system.
I'm not sure how you can remove the sheared bolt, the usual techniques may work (drilling it out with a left-hand fluted drill, etc) if not you will possibly need to find someone who can remove it by spark erosion. A replacement camshaft carrier might be a more sensible option in this case.
Post #975907 28th Dec 2022 9:12pm
Page 3 of 4 <1234>
