![]() | Home > Wheels & Tyres (L663) > Wheel Alignment - South Lincolnshire recommendation |
dazadd Member Since: 28 Feb 2021 Location: Cranwell Posts: 12 ![]() ![]() |
My First Edition 110 has excessive wear on the outside edge of the front near side tyre. I am presuming it could do with a full alignment check especially as I will be replacing all the tyres shortly.
As the car needs to go into tight tolerance mode to do this, can anyone recommend a good independent that can do this in a 20 to 30 mile radius of Grantham, I am loathed to pay dealer rates given the poor service usually received. Many thanks D240 110 First Edition (1XD3, 4xD4s and a D5 now gone) Member of Disco Forums since 2006 |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2358 ![]() ![]() ![]() |
Can only really adjust front tracking. I can't recommend anywhere in South Lincolnshire but anywhere that has recently calibrated alignment kit should be fine (though I appreciate recommendations are a lower risk approach!) > 110 XS Double Cab
The OP is talking about the new Defender where four wheel alignment is a practical proposition. Darren
Sincere apologies - my mistake!! > 110 XS Double Cab
jpboost Member Since: 13 Apr 2021 Location: Gatwick Posts: 378 ![]() ![]() ![]() |
I've previously found that a lot of bigger softer 4x4s seem to have accelerated wear on the outside of the n/s front.
My last range rover was very much like that. I spent quite a bit of time and money, to find out that it was already perfectly aligned. I noticed the issue was reduced if I took it slightly more gently on roundabouts. Obviously you need to check it, but it if comes back as 'its already correctly setup sir ' then thought the above might be helpful. |
Thanks all. New Defender so will need a full 4x4 alignment with the car in tight tolerance mode.
I’ve had a D3, 4 D4s and a D5 all with air suspension and never had the outside edge of the tyre scrub like this so I will presume it is the alignment not my driving style (hopefully😎). D240 110 First Edition (1XD3, 4xD4s and a D5 now gone) Member of Disco Forums since 2006 |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 ![]() ![]() ![]() |
Have you thought about speaking to the guys at Bowler in Belper? They're part of Land Rover's SVO dept and prepare and run the Defender Challenge 90s hopefully they'll have the required equipment & experience to help you out.
https://www.bowlermotors.com 2014 110 2.2TDCi XS Station wagon - GONE 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - GONE 2024 110 D250 X-Dynamic HSE |
Thanks, good suggestion. If they can’t they may well know someone who will👍🏻 D240 110 First Edition
