![]() | Home > Td5 > White smoke from exhaust |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 942 ![]() ![]() ![]() |
Are we talking more than the morning condensation smoke? 2008 2.4 110 Utility Station Wagon XS.
Sicastle71 Member Since: 21 Aug 2019 Location: West Lancs Posts: 128 ![]() ![]() ![]() |
Ohh I am afraid so engine was up to temp and at the end of my commute noticed on blipping throttle the white/grey smoke which would clear then left to idle for about twenty seconds repeat the throttle blipping and again an appearance of white smoke
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3542 ![]() ![]() ![]() |
Does it also do it on start up from cold?
Oil leak through turbo into exhaust turbine will create white smoke when exhaust is hot. Throttle burst will increase oil pressure, more leak. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Ok will check that on my lunch break
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5898 ![]() ![]() |
When did it last have a fuel filter change?
It’s pretty cosseted change the filters once every two month along with an oil change as it’s a daily driver. Checked on way home with nanocomm and getting an maf reading of 45 at idle it does go up but reading the figures on the net they say it should be reading 50 to 55 not tried with maf disconnected. Changed the injector loom the copper seal washers and fpr about 3 year ago and fuel pump 2 years ago runs fine most of the time but sometimes hesitant at low throttle. May be a good idea to check the injector tappers ? Smoke is evident when cold or hot with just a blip of the throttle. Thanks for any advice
