![]() | Home > Tdi > 1995 300Tdi Towbar |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2748 ![]() ![]() |
Dixon Bate will fit fine so long as you get the correct one. Pre-1998 they’re the same between 90 and 110. After that date they are different because of the 90 rear tank cradles.
This should fit your 90 assuming chassis etc is all standard: https://www.paddockspares.com/da2121-adjus...-1998.html |
Jeebs Member Since: 23 Oct 2015 Location: North West Posts: 197 ![]() ![]() ![]() |
I’m really struggling to find a kit suitable. There probably aren’t that many new/used kits out there anymore. Probably been out of production for the best part of 20 years.
Any suggestions? |
What’s wrong with the one linked above?
They’re still easily available both new and second hand. |
Grey on grey on a small iPhone screen….that’s what! I didn’t even see that!
Thanks. |
Piggy501 Member Since: 27 Sep 2017 Location: Scotland Posts: 56 ![]() ![]() ![]() |
Bit of thread drift but does anybody know of a fixed setup for a Tdi 90, or if anybody has modified a TD5 onwards setup to fit? The current Dixon Bate on mine has more wear in the pins and bores than I'm comfortable. I'm wondering if the chassis to drop plate arms from the Tdi setup would neatly tie in to the fixed TD5 drop plate.
There was a factory fixed option pre-Td5 as well, which looked like this:
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2361 ![]() ![]() ![]() |
Someone only did half a job painting that James ! 😉
