![]() | Home > Td5 > Engine warning light and limp mode, cleared with a restart. |
Lionel Member Since: 12 Aug 2008 Location: Melbourne Posts: 59 ![]() ![]() |
There is a good chance that the engine light/limp mode occurrence will have left a fault code in the ECU which can be checked in order to identify the fault.
The most likely would be a fault with the throttle potentiometer (pedal assembly), or its wiring loom. I would also first be checking for oil in the injector harness, both at the cylinder head plug, & the ECU plug under the driver's seat. This would be less likely to leave a fault code though. This sort of fault is reasonably common. Cheers, Lionel |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5331 ![]() ![]() |
i have had this with mine a few times too, just a simple engine off and one again, seems to sort it. I will have to buy a diagnostic plug in to see what the story is. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
mark1200 Member Since: 09 Oct 2011 Location: peterborough Posts: 79 ![]() ![]() ![]() |
This is classic fault of a failing MAF sensor and they do fail. just unplug it and this problem probably wont come back and its easy to check. and a good tip is to replace it with a good quality item.
Craig772 Member Since: 23 May 2022 Location: Cannock, Staffordshire Posts: 75 ![]() ![]() ![]() |
Thanks for the feedback guys. All useful to bear in mind. I've read about the throttle pot' and the dealer told me he'd had a MAF sensor issue on his that was discovered during a re-map. I'll plug my ODB reader in a see what it tells me.
