Home > Puma (Tdci) > puma 2.4 lots of obd fault codes
Sam smith
United Kingdom 2009 Defender 110 Puma 2.4 HT Epsom Green
hi
wondering if anyone can help at all as im a bit overwhelmed by the number of fault codes that are being picked up by my nanocom.
if anyone can offer any suggestions as to what i could be missing from the vehicle as well/ other ideas as im in the process of rebuilding the defender so havent ever heard it start up.
i have attatched the photos of the fault codes on the nanocom below.
cheers
Post #955217 11th Jun 2022 8:16pm
Sam smith
Post #955218 11th Jun 2022 8:18pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
wild guess: something's wrong with CAN bus communication - check looms/wires between ECUs first I'd say.
Post #955315 12th Jun 2022 8:31pm
Sam smith
ok thank you for the reply. any ideas which wires in particular as i have attempted to go through them before but there are so many that i just end up getting lost in them. they are all still out from the bulkhead so if there were some colours to follow that would be great.
cheers
Post #955542 15th Jun 2022 8:13am
Birdy
France 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
Post removed, just noticed that the truck hasn't yet been tested
Peter
Post #955552 15th Jun 2022 9:49am
Martin
Site Admin
You've read codes but what actual faults do you have?
You need to finish the rebuild/refit (from an electrical point of view), then clear codes and try again to find the actual issues.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #955555 15th Jun 2022 9:59am
hank
Is this the defender that you bought without an engine and have been sourcing parts for?
Have you got it running now? Given that it has been heavily worked on it could be anything. Are you 100% certain that all parts you have fitted are compatible with each other? Are the engine, engine harness and ECU matched to each other or sourced independently to one another? > 110 XS Double Cab
Post #955556 15th Jun 2022 10:23am
Sam smith
as far as im aware everything electrical that should be connected is connected. The issue its having is that it will crank either once for one cycle or not at all. it is as though something is cutting it off
Post #955706 16th Jun 2022 9:34pm
Sam smith
hi
no still not running and yes very much an ongoing project.
the engine and engine harness came together from one vehicle and the bulkhead, ecu, clocks came together from another vehicle.
as far as im aware they are all compatible though i could be wrong as i am definitely no mechanic.
Post #955707 16th Jun 2022 9:37pm
