![]() | Home > Puma (Tdci) > 2.4 Cylinder Head Temp Limp Mode |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4810 ![]() ![]() |
The engine is designed to shut down if it gets to a certain temperature to avoid engine damage. I would check for leaks in the cooling system. You might get a smell when driving and this would be the coolant hitting a hot surface and evaporating. I would start the engine at look at the water pump as this can leak. It could be a circlip or hoseclip that was not tightened enough allowing a hose to slip down off a pipe allowing coolant to escape. That is the simple stuff to check. Both the circlip thing and leaking water pump happened to me. Goog luck. 1982 88" 2.25 diesel
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2347 ![]() ![]() ![]() |
You are correct there is no coolant temp.
There is cylinder head temp, oil level and temp, fuel rail temp. (As well as manifold temp via MAF) I suspect the dash temp might be taking its reading from oil? Might be worth getting yourself a live readout device so you can keep an eye on temps in real time. Could be a dodgy CHT sensor or something more sinister. Good luck with it > 110 XS Double Cab |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17850 ![]() ![]() ![]() |
There is no oil level sensor on a 2.4.
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 ![]() ![]() ![]() |
Had this problem a few years ago during a 330 mile drive from Scotland. Hill climbing would cause limp mode. Slow roads and heavy traffic resulted in the same. Cruising on the motorway at 70 ish - no problem. No DTC. Luckily my indi had seen this once before, and, instead of looking for dirty fuel (my diagnosis), he checked the cooling system and found a small leak in the radiator. He explained about the CHT as you and others have outlined. Simple things first, check coolant level, then look for leaks. Good luck ![]() |
According to the wiring diagrams there is an oil level sensor signalling the ECU? I agree there is no oil level warning light ![]() Click image to enlarge > 110 XS Double Cab |
There's a connector on the harness for it, there is a sensor in the sump for it, and there is an input on the ECM for it, but it is not connected. It is there because there are other applications of the engine and ECM in the Ford line-up which did use it.
From the WSM:
I don't know if anyone has connected it to see what happens. I suspect that all it would do is add another set of possible faults. |
Greyman110 Member Since: 29 Sep 2017 Location: London Posts: 327 ![]() ![]() |
I had the same issue.
https://www.defender2.net/forum/topic75278.html Turns out for me it was the head gasket. I did change pretty much everything that it could have been before finally doing the HG. |
Very useful to know thanks ![]() |
benbumpkin Member Since: 08 Jun 2022 Location: Cork Posts: 3 ![]() ![]() ![]() |
Geez, I hope not! Thats serious money. |
Hi everyone, thanks for your help.
It was dodgy water pump, a cooling system issue, which seemed to be the consensus. I am a bit peeved that my dash indicator didn’t indicate any problem. Time to invest in an engine coolant gauge I think. |
