Home > Maintenance & Modifications > Main fuse box feed
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
Main fuse box feed
It's a well know attack method on Defenders to cut the cable that goes from the battery to the main distribution fuse box.
What's a better route for this cable?
It's a fat cable, so the routes are limited.
Post #954733 6th Jun 2022 7:38pm
Inside the cab.
Post #954734 6th Jun 2022 7:43pm
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
There’s a useful thread with photos here…
https://www.defender2.net/forum/topic61763.html
If you leave the original (disconnected) cable in place then it’s not obvious that it’s been rerouted.
Post #954738 6th Jun 2022 8:01pm
The typical route is across the back of the seat box:
More details here:
https://www.defender2.net/forum/post776416.html#776416 Darren
Post #954752 6th Jun 2022 9:29pm
steveww
Thanks JPE and LandRoverAnorak for detailed replies, just what I was looking for.
I'm not buying a ready made kit, I can make up a length of cable with terminations myself.
Another solution I'm investigating. The idea of this modification is to keep the alarm powered if the feed is cut. The alarm can only draw a few amps therefore only needs a much thinner and easier to route cable. I'll post details when I'm done.
Post #954772 7th Jun 2022 9:48am
If your Defender is XS spec it is likely (though not guaranteed) that it has a BBUS fitted, which will sound if the battery cable is cut provided it hasn't been nobbled beforehand, so to that extent keeping the alarm powered may do more harm than good (you'll just prevent the BBUS from sounding).
Depending on year there is a mode which is very advisable to take a second feed to the 10AS unit to eliminate the "indicator light fuse vulnerability" (incorporated into the dash harness on later models). It is also essential to do something to protect the BBUS, since Landrover in a moment of design genius placed it in a position where it can be access from outside the vehicle.
If you do these two modifications, it doesn't really matter if someone cuts the battery cable, the alarm will sound.
Post #954818 7th Jun 2022 4:32pm
LJMARSDEN
United Kingdom 2006 Defender 90 Other HT Java Black
This is a great idea. I think I'll be doing the same now, thanks for sharing. Thumbs Up 4.0 V8 Defender 90
My Instagram
Post #954819 7th Jun 2022 5:05pm
steveww
Thanks for the insight. I was sort of heading in that direction. My Defender does have a BBUS (not tested yet) which is protected by a few extra layers of security. I'm not aware of the indicator fuse vulnerability, please PM me with the details so I can figure out the best way to provide an extra power feed to the alarm controller.
Post #954861 7th Jun 2022 8:24pm
Have a look at this thread from aeons ago, it discusses the mod:
https://www.defender2.net/forum/topic35353.html
It describes the official mod and what it does. Later vehicles had the mod incorporated into the dash harness so don't need it.
All this info is in the public domain so no need for secrecy (and you can bet the thieves know it).
Post #954875 7th Jun 2022 9:15pm
