![]() | Home > Maintenance & Modifications > Steering Dampers......? |
| hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2358
Genuine/OEM standard
> 110 XS Double Cab |
| shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834
I can only tell you what I had done to my 2011my 110 USW around 100k miles ago.
Since then it's done at least 40k miles on continental auto routes/autobahns at around 80mph - so rock steady steering is a good thing. I explained what I wanted my Land Rover to do to Gwyn Lewis who fitted Sumo Bars and an OME steering damper, OME shocks and et10 offset wheels on 235/85/16 BFG tyres with the steering lock stops set so that the tyres miss the radius arms by 10mm at their closest during articulation. This set up works well off road as well, the better turning circle and more positive steering feel helps a lot. My advice (for what it's worth) - set your Land Rover up for what you want it to do, you may need to fit more than a steering damper to achieve your goal |
| bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2026
Hank good clip that one and confirmed my thoughts too.
Shropshire I was thinking of having the GL sumo bars and up rated track rods 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
Good plan, what I was trying to say is that there are a combination of factors that together make an improvement.
Gwyn Lewis is a helpful, if rather "straight talking" chap, a phone call to him would be a good move. If you tell him what you want to achieve, rather than what you want, he will give you straight answers based on his very wide experience. Just because you're offended doesn't mean you're right. |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939
Gwyn’s parts are good, I’m really pleased with the greasable A frame ball joint I bought and the service I had last year.
Happy to answer by email as well. Regards, steering damper and other dampers for that matter i’d stick with Genuine / OEM. The others aren’t great, they can be prone to breaking, corrosion issues. Or general failure. The Genuine ones have a good life expectancy so long as the bushes are replaced before they get too bad. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
| LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3674
just replaced a standard steering damper for an OME one, I already had the Gwyn Lewis sumo bars and disco steering arm.
my car is a road car with no steering issues I can confirm the Gwyn Lewis kit certainly tightened up the steering and removed the shake after hitting pot holes, I ran this with the standard damper for several years. The OME steering damper feels about 50% stiffer than the original (when compressed and extended off the car) and this can be detected by slightly slower RTC and further improved pot hole behaviour. I can recommend both mods ps looks good from the front too (IMO) DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
thanks for the info chaps
| 100inch Member Since: 15 May 2012 Location: Brunswick Posts: 411
Worth remembering that your spacers adding a lot of scrub radius. I would go for something like the OME as you don't want to over dampen your steering. Also avoid RTC IMO. M
| roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039
I use an original steering damper. It might even be from 2003 but for sure from before 2009.
It still works fine even with my 35"Simexes on the road. Click image to enlarge Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
| geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4410
Second vote for the Old Man Emu steering damper. Miffy has had one on for nearly a decade now, still working superbly. The only thing I have had to do is replace the bushes and I gave the metal body a paint earlier this year.
I also have a set of GL's Sumo bars on (now older than I care to remember) and have recently replaced the ball joints. The Sumo's are worth it by the way if only because you can slot a good sized spanner on to them to get old ball joints off, if you forgot to protect the threads FYI Miffy has 30mm spacers and 285/75/16 BFGs on Boosts. |
| Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3747
I’ve got a bilstein damper and it works fine, but I have to lubricate the seals every 6 months or so to stop it squeaking. It’s not the end of the world like, but I wouldn’t get another one.
