![]() | Home > Td5 > Alarm key fob replacement |
mustafasoleiman Member Since: 21 Jun 2016 Location: London Posts: 108 ![]() ![]() ![]() |
Hello
I have a 2003 TD5 Defender and the alarm fob is beginning to fall apart... Where and how can I replace it? Many thanks for the help. Alex http://instagram.com/h4vou/ |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1652 ![]() ![]() |
you can get refurbished ones on ebay and as above any good workshop can code them for you
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2420 ![]() ![]() |
Remotekey do a fully programmed key fob service .
https://remotekey.co.uk/land-rover-keys-re...mobiliser/ |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6681 ![]() ![]() ![]() |
You can buy just the case, and transplant the internals over.
YWX101010 for a genuine MG Rover part - possibly available from LR for about £5+VAT, other look for old MG Rover stock e.g. https://rimmerbros.com/Item--i-YWX101010 https://mglrparts.co.uk/products/genuine-m...3653fa7d32 Or plenty of options on eBay: https://www.ebay.co.uk/sch/i.html?_nkw=lucas+3txb+case ![]() ![]() |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5319 ![]() ![]() |
or look for rovers in the local scrap yard that may have a fob. ( bit of a long shot) Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 854 ![]() ![]() ![]() |
If you are going for a replacement case to swap your existing innards into, beware of Chinses coplies!! utter rubbish
andy2111 Member Since: 17 Oct 2021 Location: Kent Posts: 369 ![]() ![]() ![]() |
Try here, they may be able to help
https://www.technozen-electronics.co.uk/la...-services/ |
Many thanks for the help... Bought one shell from eBay and will see how it goes.
andyg0141 Member Since: 25 Feb 2022 Location: Glasgow Posts: 28 ![]() ![]() ![]() |
I went for an eBay shell and swapped the internals over and its been spot on 👍
SteveK Member Since: 21 Jan 2015 Location: Bromsgrove Posts: 335 ![]() ![]() ![]() |
My local cobbler replaces the outer shell for around a tenner!
Dirky4316 Member Since: 30 Sep 2022 Location: Worthing Posts: 14 ![]() ![]() |
Wondered if any had tried these from remote key? ![]() Click image to enlarge |
A few people have. https://www.defender2.net/forum/topic76405...=remotekey |
ChrisDefender Member Since: 29 Oct 2015 Location: Midlands Posts: 462 ![]() ![]() |
Hi Martin, will this also be OK for a 2011 Puma? Cheers |
If it helps anyone, I bought the remote key shown above and it worked perfectly when I set it up yesterday.
You literally plug the programmer into the OBD port for 30 seconds until the light goes out and that's it. My local key cutter cut the key from my original. The remote feels like it has better range and I like the fact that it's an all-in-one unit which makes my key ring less bulky - all down to personal choice though! ![]() 2002 110 TD5 Hardtop ¦ Full Puma interior ¦ Carpathian grey / Santorini black ¦ X-Vision-X poptop |
