Home > Maintenance & Modifications > Brake Caliper Inlet Machining
rallysteve
Afternoon all,
As part of my rebuild I am modifying the brake pipe arrangement and am running braided hoses straight to the calipers with banjo fittings.
I did this on the 90 project and it worked nicely, the issue with the 110 is that the calipers are not brand new (maybe a couple of years old) and although the electroplating on them is still quite good, they have obviously been machined with a spot face where the fluid inlet is. This area now has some surface rust which is no use for crush washer sealing of the banjos.
Has anyone come across any kind of guided spot face cutter (I dont have a mill) which can clean this face up? Being an M10x1 port, there isnt really much scope for a guide bush or anything.
I am sure this must be a fairly common need but struggling to find anything.
Cheers,
Post #954292 1st Jun 2022 12:01pm
You might be able to use an M10 piloted counterbore, but avoiding chatter if running one hand-held might be an issue.
https://www.google.com/search?q=m10+piloted+counterbore
Post #954294 1st Jun 2022 12:10pm
rallysteve
Cheers, that was pretty much the only option i had seen. I can see that i would be unlikely to get a nice machined face without using it in a mill though so sealing will be impossible.
Seems like i need a sort of piloted grinding stone.
Cheers 02' 110 TD5 Double Cab Rebuild Thread
Post #954300 1st Jun 2022 12:59pm
DSC-off
A bench or pillar drill and a machine vice that can be securely clamped down should be OK for this job, with the piloted counterbore. It's just taking a light skim off the surface. Thumbs Up
Post #954301 1st Jun 2022 1:25pm
rallysteve
Might give it a go then. Have got some old calipers i can practice on without any risk.
I was worried about getting then clamped well enough in my fairly rubbisj pillar drill but with the calipers split it shouldnt be too bad. At least my front calipers are the ones with the port on the back rather than the end.
Post #954302 1st Jun 2022 1:32pm
rustandoil
The "pilot" on that counterbore, will be undersize on the M10 thread...wont provide much if any guide
Post #954303 1st Jun 2022 1:34pm
DSC-off
Alternatively, a standard drill bit can be ground to give flat botton holes,
I've used flat bottom drills to flatten the bottom of holes made with a normal drill, just to take the 'V' point out. (In the video at 10:50)
Critical for machining the caliper is holding it square to and concentric with the drill or cutter.
Post #954307 1st Jun 2022 1:40pm
landy andy
Can you not get hoses with a male end, and not go the banjo bolt idea?
Post #954308 1st Jun 2022 1:49pm
rallysteve
eddie wrote:
The "pilot" on that counterbore, will be underside on the M10 thread...wont provide much if any guide
Surely if anything it will be oversize? Minor diameter of an M10x1 6H internal thread is 9.15 to 8.91mm. The first M10 piloted counterbore I clicked on has a pilot diameter of 10.5mm which i guess is intended for a tight M10 clearance hole.
Cheers,
Post #954311 1st Jun 2022 1:57pm
It might be possible to find a piloted cutter with an appropriate size pilot, or to bush the pilot spigot to fit the bore. An M10 piloted cutter will have a spigot to match the clearance diameter of an M10 bolt, not the minor diameter of an M10 thread.
(I have edited my original post here because I did misinterpret eddie's post and consequently my initial post was irrelevant).
Post #954312 1st Jun 2022 1:58pm
rallysteve
Very true but using banjos just keeps it all much neater and a fair bit more clearance between the pipe and spring when on full lock at the front.
I will keep this as a reserve for when i have ruined the sealing face on the calipers though Whistle
Cheers,
Post #954313 1st Jun 2022 1:58pm
Another option might be to use a suitably-sized Rotabroach cutter. It might be possible to centre the pilot in the fluid orifice in the caliper, or even centre the cutter on an M10 stub screwed into the hole if you can find a cutter with the appropriate bore.
Post #954315 1st Jun 2022 2:01pm
Mo Murphy
Given that new calipers aren't perfectly flat around the inlet port but a banjo will seal, I'd be inclined to just give it a careful wipe of a nice sharp flat file to clean the surface around the port up.
50 Shades of Pennine Grey
Post #954325 1st Jun 2022 3:33pm
jpboost
United Kingdom 2014 Defender 110 Puma 2.2 SW Keswick Green
Do you have a small/local engineering firm that you could use?
By the time you'd bought any bits you need, you may well find it'd be cheaper just to get someone with a mill to clean up the face. I'm all for buying tools and becoming as self sufficient as you can be, but sometimes it's worth subbing out things like this to someone better equipped.
Post #954326 1st Jun 2022 4:25pm
