Home > Puma (Tdci) > Part number for dash fixing
andy2111
United Kingdom 2002 Defender 110 Td5 HT Bonatti Grey
Does anyone know the part number for the white square screw fixing which holds the trim panel in place under the Puma gauges?
Thanks!
Post #953983 29th May 2022 3:51pm
hank
Post #954069 30th May 2022 2:53pm
andy2111
Hi,
Thanks for the info, it wasnt the right part but it led me to this. Strangely I think it's part 5 which is not on the diagram... and it says it's blue when mine is white!
https://www.lrworkshop.com/diagrams/land-r...acle_45037
Post #954073 30th May 2022 3:31pm
Dinnu
Do they look anything like the pics and links in the below thread?
https://www.defender2.net/forum/topic74416.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #954085 30th May 2022 5:37pm
andy2111
the clips on the parts diagram are blue like those in the link you sent... but the clips under my dash are white as per the picture above.... could be that my clips are not original? That would not surprise me!
Mayble I'll order the blue ones and try them - they are very expensive for small bits of plastic!
Thanks for the info
Post #954087 30th May 2022 5:49pm
andy2111
So I got some of the blue fixings from ebay but they don't fit and the hole is too small for the screw.
Maybe this has been bodged before, but I have these white fixings and one is split.
They need to have a big enough hole to accept the screw that secures the the plastic trim
Any ideas what this part is and where I can get one?
Post #955209 11th Jun 2022 5:45pm
Ashbyandy
England 2015 Defender 110 Puma 2.2 Adventure Phoenix Orange
Hi Andy,
I’ve just unscrewed mine to have a look, and mine actually has a metal nut insert, which must be fitted behind the fixing panel, and then an M6 threaded torx headed bolt that fixes the trim in place. I think that perhaps the metal nut insert on yours has fallen out behind the dash, and someone has fitted the white insert in the hole, and forced the machine screw in. Have you checked the fixing on the other side of the trim to see if it is the same,
Good luck,
Ashby Andy
Post #955281 12th Jun 2022 1:36pm
Ashbyandy
I’ve just noticed as well that the screw holding the actual binnacle isn’t original, these are black torx, and have a long self tapping type thread, ie not machine screws. Yours has obviously been removed in the past, and the original screws have been lost or misplaced,
Ashby Andy
Post #955283 12th Jun 2022 1:43pm
andy2111
Hi Andy, thanks for looking at yours, that really helps.
Mine is the same both sides, so a double bodge! It also looks like the hole in the plastic has been hacked about too.
You've given me an idea... These M6 Jack nuts should push through the enlarged hole and hopefully tighten up and grip when the screw goes in.
https://www.amazon.co.uk/Metric-Zinc-Plate...&psc=1
Hopefully this will work!
Post #955284 12th Jun 2022 2:03pm
Dinnu
Mine are also torx head. But the LRW site shows a Philips head. Maybe there were variations over the years?
https://www.lrworkshop.com/diagrams/land-r...acle_45037 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #955285 12th Jun 2022 2:47pm
andy2111
Thanks guys, I’ve ordered some M6 hex screws and jack nuts and will let you know if it works…
Post #955306 12th Jun 2022 7:31pm
