![]() | Home > Puma (Tdci) > Slow starter |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813 ![]() ![]() |
Long short but replace the battery in the handset. 1982 88" 2.25 diesel
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20961 ![]() ![]() |
I know it’s easier said than done but check voltage during cranking, you can see down to as low as 8v momentarily on Defenders but if it goes super low there is significant voltage drop there.
Check the relays are all seated and secure under the seat and that battery clamps are tight and secure. Usually these things are loose grounds, I know you have checked that but it’s a very common culprit. If not that, a loose relay or connector. Are the fixings on the starter where the live cable comes in and out secure and the Alternator connection also? Beware that these are live, but a loose terminal lug on either grounding or live is all it takes. It maybe worth continuity checking your grounds and cables in case of breaks in the latter instance but is quite rare and usually more applicable to small gauge cables. Glow plugs, do they show on the dash and illuminate then extinguish as they should in normal time as well? ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Rich T Member Since: 28 May 2022 Location: England Posts: 2 ![]() ![]() |
Thanks for the input. I’ve checked the relays but may replace them just to be sure.
When I go to crank the voltage drops to 3 or 4 volts. Glow plugs were changed about three months ago, the only thing I haven’t checked is the alternator cables. I’ll check them tomorrow and let you know how I get on. |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 ![]() ![]() ![]() |
Recon Starter…..
![]() If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
^^^^ This sounds very plausible as voltage drop is excessive.
Personally, I’d not like to see anything below 8v, and that’s bad enough. I know it’s not what you’d want to hear but for many items this is why I only believe in new parts for many things. I would tend to look at Bosch or Genuine if it was me, but the latter no doubt is at excessive price. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
I replaced mine with a Bosch at €170 plus the old one in exchange. The new starter motor had a sticker on it that sad,"Bosch. Remanufactured. Made in China." 1982 88" 2.25 diesel
