Home > Puma (Tdci) > Puma 2.2l turbo failure |
Disco_Mikey Member Since: 16 Nov 2014 Location: Dundee Posts: 531 |
check oil pressure output...
16th May 2022 12:15pm |
landhank Member Since: 27 Oct 2021 Location: RLP Posts: 37 |
Checked everything... cant find anything specific:-(
Iam going to replace both oil feed pipe and return line to make sure, that this was not the problem. Looks like the feed line will tell me again how wonderful a 2.2l engine is to work on. I found out that there is no gasket between turbo and exhaust manifold. The new garrett turbo comes with a gasket. Any ideas what to do? Replace the turbo without, or should i use the gasket (which is the better idea, i guess). Thanks and a good weekend to all. Landhank |
28th May 2022 10:57am |
