![]() | Home > Technical > How are K108 & k109 earth points secured |
| Bradders130 Member Since: 27 Nov 2021 Location: Southampton Posts: 105
Does anyone know how the K108 and 109 are secured to the engine bulkhead?
I need to clean them up after a bad connection, but I don’t want to undo the nut on 108 behind the expansion tank only to find that it was holding the bolt in place, the head of which is on the other side of the bulkhead which I can’t reach as it’s hidden behind the dash board. |
Cheers for that Mo. Do you know how the earths are secured at that point on the dashboard side?
| Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 537
They are captive studs welded to the bulkhead
Hi Linds, sorry for the late reply, but thanks for getting back.
