Home > My Defender > My 110 MILLIE. |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10513 |
The quick repairs do help once in a while and i think that your 306 must have been a defender in it's previous life 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
21st Mar 2022 11:09pm |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 4937 |
I think age has caught up with the 306 looking at it, i have had years of no trouble at all. But i will get there with it. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
22nd Mar 2022 6:41am |
Clayton. |
24th Mar 2022 9:59pm |
Last Saturday Millie went in for one of her 6,000 mile services and all was ok he put the QT diff guard back on but it was out of shape a bit, so he got it where it should be and put it on and has made it that the bolt's cant be undone by hand alone again he had a good look at the bolt holes and there was no sign of wear as if the bolts had started to come loose so there is only one other way it came off
Click image to enlarge As my birthday was in March i decided to treat my self and upgraded my speakers to these Click image to enlarge they replaced these old Kenwood speakers which i have had for while Click image to enlarge Once in a while you hope that things will go right and i thought that it would be a straight swop, no more than an hour tops, all went well with the change over and then to test them, well the 2 O/S ones were working and the 2 N/S ones were not working bang goes my theory, changed one over as the speaker might be dud one, but no it worked all ok. So what turned in to a quick ish change over turned into a long day, in fact it was over 2 days but in the end after taking everything apart to make sure all the wires were connected, i found after a process of elimination i found that one side of the speaker wires had been cut, not sure how but i have replaced the damaged bit and at the same time re-routed it as well so it does not happen again Click image to enlarge Click image to enlarge I was one happy chappie when they were all working and WOW what a difference, so in time i will replace the dash ones as well. A BIG thank you to MUD for the quick deliveries form the time of order I wish i had done this earlier as i love listening to music so it's just so much better now 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
22nd Apr 2022 9:04pm |
kenzle8a Member Since: 12 Feb 2020 Location: None Posts: 1074 |
I need to do my speakers, is that the la salle headliner Clayton?
22nd Apr 2022 9:15pm |
I don't think it is LH, it's a genuine LR one which i got from my local LR dealership some 10 years ago 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
22nd Apr 2022 9:51pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3616 |
Nice work Clayton, looking good… and loud!
22nd Apr 2022 10:09pm |
Thanks Co1 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
22nd Apr 2022 10:18pm |
So it seems i'm getting like Co1
As much as i liked the Blindo's i just thought they still looked to fancy for Millie as i kept seeing pic's of her with the modular's on, so i have been running her with the modular's back on to see if i was right Click image to enlarge I do think that Millie suits them being a utility landy, so i went ahead and got some new ones and on Saturday morning i went to my local ATS to get them changed over before Click image to enlarge Click image to enlarge after Click image to enlarge Click image to enlarge The old modular's will be getting refurbed, shot blasted and then powder coated. I'm well happy with the end result 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
23rd May 2022 8:48pm |
That looks great. I do like a set of modulars and agree about the utility look. If you're getting the olds ones refurbed, can I suggest silver as I think that'd look really good on your truck? Darren
24th May 2022 6:45am |
Thank you Darren
I have never thought of silver but i am now but i think someone would have to do a photo shop so i could see for sure 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
26th May 2022 8:24pm |
Cragster69 Member Since: 15 Jun 2021 Location: Scotland Posts: 166 |
Clayton, I've taken inspiration from your set up, needed a bit refinement which was done with a needle and thread when I got home. I've attached a loop to allow the back of the awning to be tied off on the roof rack. Click image to enlarge You and Millie are an inspiration and just shows how long something can last if it's looked after. Craig. “Don't believe everything you read on the internet.” ― Abraham Lincoln www.scotgrc.co.uk |
15th Jun 2022 3:06pm |
Many thanks Cragster69
Great that you had some inspiration from my efforts and you've done a good job there 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
31st Mar 2023 11:35pm |
Good to have you back Clayton. Craig.
1st Apr 2023 12:34am |
