![]() | Home > Technical > Newbie Landrover Owner - anti Roll Bars |
Tazz Member Since: 24 Mar 2011 Location: Harrow Posts: 90 ![]() ![]() |
Yes, whilst they can reduce the off road capability, their main purpose is to improve on road stability. If your landy is going to be primarily a road car and non-aggressive off roading, it may be worthwhile fitting them. |
df1 Member Since: 06 Aug 2011 Location: Ireland Posts: 221 ![]() |
Which ARB's would be the best to aid on road stability ?
Was thinking of the kits Paddocks do but I've had bad experiences with Britpart stuff before. |
The anti roll bar broke on our 300 TDi so was removed and never replaced. That was about 5 years ago.
Our 09 plate TDCi USW has anti roll bar in place. I have never really noticed a difference between the two vehicles in handling. There again I do not throw the 110's into the corners. It has been commented that the body moves more on the 300 TDi by people following me. I am not rushing into replacing the ARB on the 300TDi, well it has been 5 years+ Brendan PS No problems with MOTs either! |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
The ARBs have'nt stopped me so far, been told i sometimes have a corner off the ground but the traction control and diff lock has done it's stuff without drama, even on slippery gloopy surfaces
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
I fitted genuine front and rear ARB's to mine a couple of years ago, amazing difference in stability on the highway. Far less body roll. Wouldnt go back on non fitment again
![]() Still greenlane as much [and enthusiasticly] as i never did, not caused me any problem so far ![]() |
stevie d Member Since: 09 Nov 2009 Location: Bishops Stortford Posts: 342 ![]() ![]() ![]() |
I have a TD5 without any ARB's.
Never had an issue with it, may be more of an issue if carrying a lot of wieght? Steve ![]() Discovery 3 HSE BMW 330i Coupe |
babbolla Member Since: 02 Oct 2011 Location: Ripon, North Yorks Posts: 9 ![]() ![]() |
Thanks, but it seems to be a 50/50 split!
My landy is a little top heavy at the moment whilst fitted with a roof-rack. However, I am planning to line the back with ply to improve insulation. Are genuine ARB better than other makes? Cheers ![]() |
Basic rule is to keep weight as low as possible and preferably between axles.
Insulation? Close cell foam is probably a better insulator and also lighter then plywood. Brendan |
That's why I haven't fitted Mudrails to mine ![]() http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
