Home > V8 > 3.9 on SUs - which cam?
Ranger 6
United Kingdom 1988 Defender 90 V8 Petrol CSW Rimini Red
It's a std 3.9 9.35 block which has been re-bored, decked, the heads have been skimmed as well. That alone will up the CR a bit further. It's staying on carbs and I'd like to keep the drivability of the V8 so not too peaky.
Question: What Cam to keep the nice low end grunt?
Is the Real Steel Hurricane any good or should I be looking at a Kent H180? 90 V8 CSW - 1988
Post #947527 30th Mar 2022 4:39pm
MercianRover
United Kingdom 1998 Defender 110 300 Tdi CSW Java Black
I ran the same setup and used the standard camshaft and BDR profile needles.
Post #949014 11th Apr 2022 2:53pm
Ranger 6
Thanks - I have already switched to BBWs and it's made a massive difference to drivability.
My thinking is that a slightly improved cam will just give that extra 'spark' over a std one. 90 V8 CSW - 1988
Post #950997 29th Apr 2022 12:46pm
MercianRover
Do you have the 3.9 exhaust setup?
Probably as well to get the distributor rebuilt and give the ignition system a refresh - Lumenition is another thing to consider.
Post #951007 29th Apr 2022 3:28pm
Ranger 6
Yes, I have got the 3.9 exhaust on it already.
Does the electronic ignition really make that much of a difference? 90 V8 CSW - 1988
Post #953492 24th May 2022 4:02pm
Ranger 6
Leaning towards this one: https://www.v8tuning.co.uk/custom-ground-camshafts 90 V8 CSW - 1988
Post #954179 31st May 2022 3:01pm
MercianRover
No more faffing around with points gap and suffering the results of vaiable condensor quality, just a consistent spark under all conditions.
Post #955041 9th Jun 2022 2:09pm
Ranger 6
Thanks - I'll have a look at that when the engine gets built 90 V8 CSW - 1988
Post #955604 15th Jun 2022 5:22pm
Ohlins
France
My 3.9 on SU carbs has this one fitted...strong low end to mid range power.
https://crower.com/camshafts/land-rover/la...00cid.html
https://crower.com/printcamcard/?part_num=55229&x=0&y=0
All the best
. Army 110 3 Door 200tdi
Army 110 3 Door V8
Army Lightweight 2.25 Petrol
110 300tdi 5 door
Yamaha XT660Z Ténéré
Gas Gas 300EC Ohlins
Post #973490 5th Dec 2022 5:11pm
MercianRover
Red line is pretty low on that Crower cam, admittedly the Rover V8 isn't great at high engine speeds but 4500rpm?
Post #973491 5th Dec 2022 5:24pm
Ohlins
France
Indeed, though I must say I don't find it lacking in the low box and in high it cruises along just nicely. As you say these old pushrod two valve engines shouldn't work too hard...having said that my previous work V8's never died no matter how badly we treated them!!!
This is my first Defender V8/LPG with the engine installed as is when I bought it so I'm keen to learn about it over this winter.
All the best
Army 110 3 Door V8
110 300tdi 5 door
Post #973772 7th Dec 2022 10:23am
Ranger 6
Thanks - all useful info
The engine is still waiting assembly as the house renovation came first Very Happy 90 V8 CSW - 1988
Post #978828 19th Jan 2023 3:10pm
