![]() | Home > Td5 > Potential faulty MAF sensor |
jimbo55 Member Since: 15 Jul 2020 Location: Midlands Posts: 405 ![]() ![]() |
The easiest way to check if it is the maf sensor is to unplug it and drive round with it disconnected. The ECU will resort to a default calculation instead of the measured value. If it drives fine then look to replace the MAF, if it still occurs then you’ll have to dig a bit further.
The above is spot on
Guinness Member Since: 04 Mar 2021 Location: Scotland Posts: 58 ![]() ![]() |
great, I will have a go now. Will this have any negative effect? As it is only an intermittent problem I may have to have it unplugged for a while circa. 1 month to be able to be sure?
pjm-84 Member Since: 12 Apr 2021 Location: Hampshire Posts: 711 ![]() ![]() |
No it will hopefully fly in comparsion. Had a miss on my TD5 and oil from the performance filter was coating the MAF sensor. When I disconnected it was sooooo different.
My fingers are crossed, ill update in a month or so!
