![]() | Home > Td5 > sump plug leak |
| BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 928
Are you using new copper washers or reusing an old one? Charlie
1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
| alexatnd Member Since: 19 May 2015 Location: Yorkshire Posts: 292
Always use a new one Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Gertie - 1999 110 TD5 - new chassis etc back on road Effie - 2004 110 TD5 County |
Make sure the threads in the sump or on the plug aren’t damaged then. It’s quite possible to damage them by over tightening. Charlie
and if they are ?
replace sump? drill out thread and put in an insert ? Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - new chassis etc back on road Effie - 2004 110 TD5 County |
| jimbo55 Member Since: 15 Jul 2020 Location: Midlands Posts: 408
If it’s been over tightened to the point you need pipe over a breaker bar then it’s likely that the threads have been damaged either one or both of the plug and sump.
New sump plug is an easy thing to change, if it is the sump then you could probably find a decent second hand one at a reasonable price. A new sump is very expensive. Rightly or wrongly, I always use blue hylomar to help the sealing as well as a new copper washer. |
I’d just try and find a good secondhand sump. They’re around the £50-60 mark on eBay. Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6059
I would try fitting a Femco quick drain plug That way if it works ok, then you won’t have to disturb it next oil change.
| roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039
I use silicon sealant. I don't know how you call it in englisch. The head gasket stuff.
It seals good and stick so you don't need to overtighten it without the fear of loosing the plug. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
| All times are GMT |
