Home > Tdi > TDI 200 Injector Issue
Page 2 of 2 <12
cykoh85
Malaysia 1990 Defender 110 200 Tdi SW Santorini Black
Ok, thank you Thumbs Up
Post #950749 27th Apr 2022 3:22pm
cykoh85
Hi Dinnu
want to ask you and show you something. Aft I drove around 120 miles last weekend. I noticed some engine oil appeared on the engine cover (please see attached pictures).
Some underneath (please see an attached pictures) also have some oil leaking.
Thank you so much!
Post #951674 5th May 2022 4:03pm
Dinnu
Picture 1. If there is no oil dripping from above, then most possible culprit is the rear crank shaft seal. To fix is either engine or gearbox+transfer box out. Depends how much you are equipped... if have an engine hoist, engine out is probably easier.
Picture 2. Transfer case output seal. This is not a difficult fix. maybe 30min to 1hr job. Could be just the seal, but if the output flange is pitted, better replace it as well.
Picture 3 n 4. Looks like top cover gasket. Very easy job. Just take top cover off, replace seal, or apply a smear of sealant. While you are there, check the valve clearances. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #951696 5th May 2022 6:39pm
cykoh85
Ok, thanks Dinnu...I will check all of them and see.
Post #951795 6th May 2022 2:53pm
cykoh85
Dashboard meter appeared "err" msg
Dear Dinnu
Hope you are fine. I would like to ask you something abt eletrical issue (pls refer to the pic). Recently I took out radiator for maintenance, so I pulled out one of the car battery connector as did not drive for one week+, I cannot start the car aft put back the radiator, so I used jump start and charged the car. Aft that the dashboard meter became "err"..does the fuse dead? Or wiring problem?
Appreaciated your helps and reply.
Post #963489 31st Aug 2022 11:30am
Dinnu
The 200tdi gauge is full mechanical, so looks like an aftermarket gauge. Not familiar with that.
Perhaps some other forum member can advise. I put your picture below:
Post #963516 31st Aug 2022 2:35pm
cykoh85
Ok, Dinnu. thanks for your replied. I suspect the electrical shock, because after I recharge/reconnect the car battery, it become like that...anyway, see any other members can answer or not..thank you so much;-)
Post #963531 31st Aug 2022 3:41pm
Dinnu
I googled ‘kus speedometer’ and got on this site: https://kus-usa.com/product/gps-speedometer-gauge-cmsb/
Perhaps try dropping them an email. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #963561 31st Aug 2022 7:05pm
cykoh85
Hi, Dinnu. Really appreciated. Anyway, I tried google and see some info abt speedmeter did not work properly aft changing the car battery and etc. The tip was disconnect the car battery and reset everything, then should be fine. I will try this tomorrow and see.
By the way, do you know the transfer box oil leaking mainly because of the input seal and immediate shaft? Can just fix with reseal the transfer box as well as change the new bolts? Pls see pic and reference link:https://www.defendersource.com/threads/reseal-transfer-box.39018/
One more i did asked you abt the engine oil leaking previously, you told me could be rear main oil seal, T seal or forgot the name, haha...pls sèe pic as well, I noticed the oil filter also having droplet. Anyway, I noticed oil catch can (D1 SPEC) appeared outside the can..i am still investigating the leaks..😂
Thanks for your time answering all of my questions😊
Post #963677 1st Sep 2022 3:18pm
cykoh85
Hi,Dinnu..the speedmeter back to normal aft I have been disconnected car battery. But km units still holding the same before the speedmeter haywires..
Anyway thank you ..and thanks God:-)
Post #963758 2nd Sep 2022 12:43pm
Dinnu
cykoh85 wrote:
Is the colour of the oil red? if yes, it could be ATF which is the oil specified for the LT77 (main gearbox).
Keep in mind that when driving, the wind will blow the oil towards the rear. So if main gearbox is leaking, you might think that the transfer case is leaking too.
Best is to give a thorough wash, dry. Take for a short spin, and check for oil drips right away. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #963761 2nd Sep 2022 1:44pm
cykoh85
Yes, it is red colour. So what is the main thing that cause the leak(gear box) if it is gearbox leaking? Thanks
Post #963762 2nd Sep 2022 1:59pm
Page 2 of 2 <12
