![]() | Home > Faults & Fixes (L663) > Floormat fastener broken |
Kubrick1978 Member Since: 01 May 2021 Location: Midlands Posts: 101 ![]() ![]() |
Let me know what happens - that surely shouldn't be happening! I'm always taking out my rubber mats to hose them down - hopefully this isn't a common problem.
graemesmith1960 Member Since: 03 Sep 2021 Location: West of Scotland Posts: 80 ![]() ![]() |
Just found this post. Search facility didn’t find it. I’ve got the same problem and it happened again after a replacement.
From my other post: Has anyone else had the retaining studs for the foot mats come out of the floor? My drivers side mat pulled the stud apart the first time I tried to remove the mat leaving a hole in the floor with no way to reattach the stud. The dealer duly ordered a new clip and 2.5 hours of labour later it was fitted. Guess what? First time I remove the mat again the stud comes apart. This time I can just see the other bit of the stud under the floor and it looks a pretty poor design. Either it is supposed to be compressed by a ring which has broken again or else the hole in the floor is supposed to do the compression and the hole I have looks like it has been reamed out a bit so is pretty large. I haven’t heard of any one else with this issue but if there is what was the solution? If my suspicions are correct I’ll need a new floor panel. Defender D350 X-Dynamic HSE 110 MY25 Carpathian Grey |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 460 ![]() ![]() |
Next time I will fix it myself, Just by using superglue. No Mud flaps for my 90.!
----------------------------------------- P300S MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
