![]() | Home > Td5 > TD5 rear door washer jet - help! |
Paddington Member Since: 15 May 2020 Location: Oxford Posts: 43 ![]() ![]() |
I suspect I could fit the puma version - not that they look the same.
freddie206 Member Since: 18 Oct 2015 Location: Skipton Posts: 90 ![]() ![]() ![]() |
I think this is what you’re after…
https://www.lrworkshop.com/parts/LR061678 |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6682 ![]() ![]() ![]() |
EAM9332 is the pre-1987 model year rear washer jet.
LR061678 1987 onwards ![]() ![]() |
Thanks for the replies - that's it! i've double
checked my parts manual and the part you've both identified isn't in the manual - which covers all types upto and including TD5. This forum comes up trumps again. Cheers both! Neil |
It’s a superseded part from LR034310, AMR3026 and PRC5802.
One of those (the latter two) is likely in your parts book ![]() ![]() ![]() |
Thanks Martin
