Home > Td5 > Cruise control on a MY2000 Defender td5 with a newer ECU
mafiekazen
Netherlands 2007 Defender 110 Puma 2.4 CSW Stornoway Grey
Hi guys,
I’ve already searched but didn’t found the right answer.
So I have a 2000 Defender Td5 with the P10 engine, the previous owner had troubles with the ECU and replaced the ECU with a newer one.
I am aware that it is not that easy to install cruise control with a defender pre MY2002. When reading out the ECU I found these readings. A NNN000120 ECU with a production date 12/2001. So this gave me a little hope that this ECU is capable of just wiring the three wires and a two switches and have a working Cruise Control.
Does anyone know?
Post #950604 26th Apr 2022 10:32am
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
Hi my 10p ecu died a while back and I replaced with an NNN.
Fitted cruise control wiring as per all the diagrams online and it works great. Depending on your transfer box ratio you may need a speedo healer if you’re running 1.2.
Having a nanocom is handy to check your switches are correct.
Post #950610 26th Apr 2022 10:54am
roel
Should work.
You might have to get used to it and think it isn't working at your first try as it is a slow system.
The way I do it is keep pushing the accelerate button till you feel it starts pulling. Roel
2003 90 Td5 (2009-now)
Post #950661 26th Apr 2022 7:42pm
