Home > Puma (Tdci) > Intermittent power loss
Jefinabox
Ey up,
I've had my 2008 2.4 for a week,
It's got about 70k miles on, an alive stage 1 remap and silicone intercooler hoses.
Occasionally when I drive from cold or warm, it'll make no power bit plenty of black smoke, it's as though the turbo isn't spooling.
If I turn the engine off and on, it'll do it again straight away. If I lock and unlock, then start the problem clears.
Does anybody have a clue what this could be? Thanks in advance
Post #950258 23rd Apr 2022 6:44pm
Plug in and look for DTC’s.
If you don’t have that available to you,
lube your turbo actuator pivot points.
Try cleaning your MAF and MAP sensors (don’t touch use brake or MAF cleaner only).
Check air filter.
Consider changing the VCV, look at all the above first before this though.
Ideally you want to have it plugged in to find the codes if any are present for faults. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #950264 23rd Apr 2022 7:09pm
bear100
Could be a delaminating turbo hose? 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #950277 23rd Apr 2022 8:32pm
Jefinabox
Thanks for that, my cheap obdii scanner returned no codes, so I'll clean everything and lube the turbo pivots tomorrow and see what happens.
Post #950354 24th Apr 2022 6:08pm
One of the few things that doesn’t flag a DTC is the VCV. When that fails or is risking it doesn’t show anything up.
Turbo actuator can get sticky, best to remove the upper linkage carefully and operate wastegate by hand then lube be careful not to lose the circlip.
Or if you want to be on the safe side lube the pivot points in situ for now and leave it at that.
Worth trying anyway. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #950387 24th Apr 2022 9:11pm
Jefinabox
Just an update, I followed your advice and cleaned/lubed everything. The problem hasn't been back since and I've got a spare vcv just in case.
Ta
Post #951035 29th Apr 2022 7:38pm
Good news. Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #951048 29th Apr 2022 8:55pm
Jefinabox
Ugh, the problem came back so I swapped the vcv for a new one, I didn't do the learning program because I don't have the capability.
Exactly the same thing happens, sometimes it's fine, others I've got no power and loads of smoke. Crying or Very sad
I'll dismantle the actuator tonight and lube properly.
Post #951768 6th May 2022 10:19am
