Home > Puma (Tdci) > Tik tlk tik
Page 1 of 3 123>
110 Iain
United Kingdom 2008 Defender 110 Puma 2.4 USW Chawton White
Tik tlk tik
OK so latest problem with 110 is tik tik tik noise on front drivers side it relates to wheel speed it's the in gear or coasting and with brakes applied it sounds like stone in tyre but have checked jacked font up spin wheel no noise checked caliper and disc cover for jamed stones wheel bearings new plus cv joint year old ujs seem fine no play so can it be diff? At end of tether now had so many issues with her last 6 months as always any help from you guys would be great Endeavour To Persevere
Post #949767 18th Apr 2022 6:17pm
BrickBox
Could it be CV joint when under pressure ( all 4 wheels on the ground) ? 2017 L494 Range Rover Sport SVR
2008 2.4 110 Utility Station Wagon XS.
Post #949771 18th Apr 2022 6:26pm
110 Iain
I thought if it was cv it would be worse on full lock cv only year old plus new shaft and swivels had drive flange of its mint its hard to pin it down as you say only occurring when on road it sounds like a ligh metal on metal similar to the sound of my rear pads jumping which I had a while back thanks for helping Endeavour To Persevere
Post #949774 18th Apr 2022 6:34pm
Are you sure you don’t have grit or stones in the tyre tread?
Pick them all out from and rear and go from there, maybe barking up the wrong tree here but it does happen. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #949777 18th Apr 2022 6:45pm
110 Iain
Yup cleared all 4 tyres there was a few small stones in them though have had the wife walk along side car listening to click click sound and she says it sounds like something outside rather than internal neibours think we are mad any way it clinks even when crawling a 5 mph thanks for reply Endeavour To Persevere
Post #949780 18th Apr 2022 6:53pm
Kevlar
Czech Republic 2010 Defender 90 Puma 2.4 SW Santorini Black
I have the same noise, I also thought it was a stone in the tire but then I heard it while stationary.
Its definitely more obvious while driving though but doesn't seem to align with engine revs.
I'm yet to locate the issue so hopefully someone here has an idea ?
Post #949835 19th Apr 2022 12:33pm
110 Iain
My tik tik tik noise is related to wheel speed pushed the car today and could hear it with each wheel revolution can hear it at slow speed when stick head out of window not sure if it is there at speed to much road noise car driving fine anybody out there know if cv can make steady clicking even in straight line I'm worried might be diff but no clunk's or any thing else in driveline? Should I pull cv out its ony year old Endeavour To Persevere
Post #949838 19th Apr 2022 1:16pm
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
Do you have the brake disk backer plates? Has one rusted so it’s moving and hitting the disk? Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #949843 19th Apr 2022 1:54pm
110 Iain
Hi yes checked them then removed to rule out that's what I thought it was at first as have had stones trapped before Endeavour To Persevere
Post #949846 19th Apr 2022 2:07pm
Dinnu
Could a stone have gone between the swivel pin housing and the disc brake? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #949856 19th Apr 2022 4:08pm
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
Turn the infotainment volume up Whistle Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #949866 19th Apr 2022 4:51pm
110 Iain
Update so tick noise getting proper loud now can hear it cruising at 40 so pulled the driveshaft and cv joint out it was mint wheel bearings all good so at a loss now could diff make light tapping noise that matches wheel speed think checking diff a bit beyond my skills any ideas out there Endeavour To Persevere
Post #949874 19th Apr 2022 7:19pm
Co1
I don’t think anything in the diff would make that noise if it failed, you could drain the oil and see if anything falls out to be sure. The only thing that you would possibly hear in the diff at 1x rpm would be crown wheel teeth missing, but this is unlikely to be audible unless you are missing a few in a row and the pinion is falling out of mesh. Can’t help but think you’d have bigger problems though.
Post #949877 19th Apr 2022 7:44pm
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
Have you checked the UJs with the prop removed from the vehicle? Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #949878 19th Apr 2022 7:45pm
Try spinning wheels by hand whilst secured properly and see if you hear anything around. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #949879 19th Apr 2022 7:49pm
Page 1 of 3 123>
