![]() | Home > Technical > what the hell is going on here |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5331 ![]() ![]() |
Pulled onto the drive way after my little beer trip from makro, and i bumped into my mam, chatted to her about what had gone on today etc, she happened to notice this
![]() Click image to enlarge and this ![]() Click image to enlarge has any one ever saw this happen with their rear lights? one is more distorted than the other. I replaced these a couple of years ago, due to the lens been that badly matted. bearmach these are. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
gcc130 Member Since: 05 Jun 2015 Location: Wiltshire Posts: 783 ![]() |
I’ve had the same in the past on series Landrovers. Obviously got too hot, don’t know why🤷♂️
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17876 ![]() ![]() ![]() |
Faulty or incorrect bulb overheating the plastic.
Defender SVX Member Since: 29 Jan 2009 Location: Co Durham Posts: 730 ![]() ![]() ![]() |
You are obviously a modern style driver using the brakes far too often this melting the plastic lens
![]() Try the old school method of anticipation and gears to slow, brakes to stop. ![]() Or change to LEDs ![]() 16 Focus RS Nitrous Blue. 11 FFRR TDV8 Vouge SE Black Black. 08 DEFENDER SVX SOFT TOP (SUPERB) 08 DEFENDER 110 DCPU Stornoway grey (Overland Exploration Unit) 05 Fiesta ST 150 Van 04 Jaguar XKR 4.2 Supercharged V8 02 DEFENDER 90 TD5 (next years soft top project) 95 DEFENDER 110 CSW 300 TDi Phoenix black 95 DEFENDER 90 HT Monti Carlo blue COUNTY 300 TDi 67 109" SERIES 2a TUNED 200 TDI 64 DAVID BROWN 990 rat look 55 86" SERIES 1 |
not me cuz
![]() My dad is thinking the bulbs maybe faulty, as i did change these when i swopped the lenses over. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3588 ![]() ![]() ![]() |
Those bulbs are 5W for side lights and 21W for brake light. So you can have total of 26W going through. Can generate quite some heat. But ensure that they have been mounted the right way (the bayonet pins are not symmetrial), as if they are incorrectly fitted (trust me can be done), you have 21W side lights and 5W brake light.
Side lights are on for a longer period of time than brake lights. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
i had a look at the rear lights, to double check the lights bulbs as mentioned, and they are in the correct way. I am suspecting that the plastic lens are poor quality, these were bearmach i have swopped these to wipac or what ever these are called. They seem a better quality.
![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
Solihull Boy Member Since: 02 Oct 2012 Location: YORKSHIRE Posts: 68 ![]() ![]() ![]() |
OEM parts always, if possible - also do you sit for long periods with the footbrake applied rather than using the handbrake, say in traffic. There is obviously a heat build up, and no cooling from any airflow Retired from the day job and now self employed - what a life!!
the gamekeeper Member Since: 01 Jan 2010 Location: Surrey Posts: 97 ![]() ![]() ![]() |
If you done that the stop start wouldn’t cut in 😁
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 857 ![]() ![]() ![]() |
Something that has been niggling away at the back of my mind since this thread was first posted is that there are differences in the lamp housings from 300tdi onwards and either the lens body or lamp holder that clips into it are different depths depending on if it is designed for a 5W marker light or a 21W stop/indicator light. It's been a while since I have touched my lamps so can't quite remember exact details, but is it possible that the lamp fittings have been mixed up so that the stop lamp is now sitting too close to the lens?
Aren’t the bayonet pins on the stop/indicator lamp a bit offset? There are also 2 positive connections on that while the side light only has one positive connection. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
