![]() | Home > Td5 > TD5 rev counter hit and miss. |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5347 ![]() ![]() |
had the car running today, and then the rev counter just stopped. if i mess with the blowers it sort of comes back on line? when i fire the car up into life, all is working, but after a bit of a drive, the rev counter just goes like that,
![]() Click image to enlarge Defender TD5 90 ---/--- Peugeot 306 HDI hatch back In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
balmybaldwin Member Since: 17 Apr 2021 Location: Surrey Posts: 196 ![]() ![]() ![]() |
Have a look behind the dash.... sounds like a poor connection being jogged by the fan leaver. These weren't standard, it's possibly an after market add on so might have bodged wiring in need of a repair
You might check the voltage.
When my Alternator died while off-roading, on the way home the rev counter was the first thing that stopped working. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 394 ![]() ![]() ![]() |
The tachometer on my Td5 receives its signal from the ECU not the alternator. I wonder if you have some connection or earthing issues with the instrument pack?
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
As its down past the zero mark I'm pretty certain it'll be a power problem rather than a signal problem.
Mine sits like that with the ignition off, then when you turn on the ignition the needle rises to zero. I'm sure you'll find a poor connection behind the dash binnacle ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
cheers pal
![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
