![]() | Home > In Car Electronics > Puma Windows lift connector pins |
I think this is the connector and terminals you need - https://www.mobilecentre.co.uk/jlr-2-way-m...-connector
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17935 ![]() ![]() ![]() |
The inserts look very similar to Econoseal ones (as does the seal) but without an indication of the scale it is hard to be sure.
Anvil Member Since: 16 Jan 2009 Location: Milan Posts: 21 ![]() ![]() ![]() |
Thanks ![]() I've spent half a day searching resellers sites and I wasn't able to find anything ... not to mention google Unfortunately that site only ships overseas orders starting from £150, but at least I have the connector code Last edited by Anvil on 8th Apr 2022 11:24pm. Edited 1 time in total |
Yep, they're so similar I thought I could use those I have, but they are a bit smaller than the original.
I need to measure it again as I deleted the file where I noted it ![]() |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
The connector is a Sumitomo HM series but the terminals are universal between the MT/HW and HM series.
The mobile centre link is correct but i would imagine you can find the terminals more locally. Simtek can also supply: https://www.simtekuk.co.uk/product.php/sum...:::7169176 Alternatively PaulMC (if he is still around) should be able to supply. C0326 is a harder one to source. Paul is the only source i know: https://www.ebay.co.uk/itm/YPC500150-Defen...635-2958-0 Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread |
Thanks, this is helpful. I'll search it from some local dealer
Yes, me too ![]() |
