Home > Maintenance & Modifications > Engineering Shops in surrey
miker
So it seems the semi-inevitable has happened and my TD5 exhaust manifold has warped.
I have a squealing noise under load and some soot around cylinder 1 and 5 on the manifold.
Does anyone know of a good engineering shop around the top end of Surrey? Would like it flattened, and will probably get a hole drilled and tapped at the same time for an EGT probe. May well do a quasi-deweb of it myself at the same time.
Post #948556 7th Apr 2022 10:38pm
landy andy
If you need it as your daily drive I have spare manifold here. Warped (don’t know how bad, as I got it return from last manifold lending) so needs sorting. I do also know of an engineering place local ish to me. But I’m in Hertfordshire
Post #948567 8th Apr 2022 5:54am
rallysteve
I had mine done via mail order here: https://ldsengineering.co.uk/product/land-...lkc102030/
Not sure if they are still trading though.
Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread
Post #948573 8th Apr 2022 7:29am
