Home > Puma (Tdci) > Clutch slip or something else ?
Page 2 of 2 <12
stew 46
England 2010 Defender 110 Puma 2.4 USW Bonatti Grey
I had signs of leaks on mine
Post #947461 29th Mar 2022 9:42pm
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Okay so I took the 130 for a good drive , it drove normally for the first 15 minutes then the loss of power reappeared.
Out of gear the engine rev’d freely but the moment I put it in gear I struggled to get up the hill or accelerate on the flat in any gear.
There was no burning smell this time.
Checked all wheel hubs for signs of brakes sticking, they were all cool to touch, as was the handbrake drum.
Diffs were warm but not hot either.
The defender coasts along when out of gear so I doubt it’s the drive train .
Turbo actuator appears loose if not very loose !
Will check the wiring looms for chaffing next.
Had a new fuel filter and air filter on 27/01/22
It has a 170 BAS tune with BAS intercooler and EGR deleted.
The only other possible lead is that there’s a reverberating through the floor at the low end of the rev range, in all gears. Almost like you ought to be changing down.
Also clutch peddle seems lower than normal, possibly an inch or so lower than the brake ?! https://www.instagram.com/hustynminepark/
Post #948186 5th Apr 2022 3:42pm
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
any codes? Roaming around 🇳🇴🇨🇭
Post #948190 5th Apr 2022 4:48pm
Bluericky
Post #948191 5th Apr 2022 4:49pm
Angus_Beef
how old is the VCV? Roaming around 🇳🇴🇨🇭
Post #948192 5th Apr 2022 4:52pm
Bluericky
Funnily enough that was also replaced in January, with one from PF Jones . https://www.instagram.com/hustynminepark/
Post #948193 5th Apr 2022 4:53pm
Though a failed clutch switch should flag up a DTC but not necessarily illuminate the MIL.
(Amber dash light).
If you have a Multimeter, it maybe worth checking it is working as it should.
Set it to a beep continuity check, if you have someone who can depress the clutch for you with probes on the two pins it will beep with the clutch down which means the clutch switch is working. With the clutch up the beep will go off if it’s working correctly.
If you don’t have someone to assist use a couple of little test leads instead and listen for it. You don’t need the ignition or engine running.
The plug will come off if you press the little metal bar in and remove the plug, repeat to refit.
Other than the clutch switch the clutch is entirely mechanical and hydraulic, the clutch switch if it fails can cause performance issues as it’s directly connected to the the ECU and cuts torque a little at times.
However, you can bypass it like I have as well and driving it with care will be no problem.
Note you cannot just unplug it and leave it, it’ll need a bypass by closing the circuit or a fully working clutch switch.
I would say, if the clutch switch is working as it should then it isn’t an issue.
The clutch switch if it fails to operate as it should can cause performance issues, but it should trigger a DTC.
If you bypass you can just clear the DTC and it won’t come back unless battery is disconnected, even if it does it won’t trigger the MIL or cause a problem.
I fitted a new clutch switch on mine just the other day with new MC, even though I have been running mine bypassed for years now. The original clutch switch failed.
Test it would be an idea if you can, it maybe nothing to do with it but worth doing if you have a Multimeter. Thumbs Up
Just an idea. Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #948253 5th Apr 2022 10:02pm
Bluericky
That’s all great advice, thank you.
Infact I did as you suggested and bypassed the clutch switch on my other defender, it eliminated the rev hang I had at the time !
I will test and see 👍🏼 https://www.instagram.com/hustynminepark/
Post #948259 5th Apr 2022 10:23pm
Good luck, and yes if you had a Rev hang then that would have been a failed clutch switch.
As you know, two options bypass or replace for that.
It may trigger a DTC, but not always but that’s the only performance / electric mic link between the clutch and engine performance.
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #948328 6th Apr 2022 1:56pm
Bluericky
I thought I would update where I’ve got to.
Having cleaned all sensors, checked brakes, tested the clutch on a steep hill, I was a little flummoxed as the symptoms started about 10 minutes into pretty much every drive.
Took it to the local indy and he suggested it may be a blocked Cat .
We took it off, had a look, it looked a bit gummed up so knocked it out and hey presto, there hasn’t been a problem since !
So no idea why it smelt like a burning clutch or sent the defender into a sort of limp mode after almost 10 minutes on every run but it did !! https://www.instagram.com/hustynminepark/
Post #950668 26th Apr 2022 8:39pm
stew 46
Good you hopefully got it sorted Thumbs Up
Stew
Post #950674 26th Apr 2022 10:13pm
Bluericky
Okay so bizarrely the 130 is having the same issues, the CAT was clearly not the issue and to be perfectly honest I’d have been extremely surprised if it had been !
I’m going to head towards the clutch / slave as being the culprit.
Today driving on a 40 mile round trip it was struggling on occasion going up hills and even on the flat , particularly noticeable when changing up a gear.
Having to blip the accelerator before changing and occasionally depressing and releasing the clutch for a second time to get a decent bite made it mildly better. The revs still don’t seem to relate to clutch slip but all of the other symptoms are there.
I will report back. https://www.instagram.com/hustynminepark/
Post #954689 6th Jun 2022 11:45am
Bluericky
Just to close this topic.
The clutch was indeed on it's way out but replacing it did not cure all of the issues.
I decided to replace the VCV again, (last changed in January...why not) and hey presto, all back to how it should be.
I'm more concerned as to why it may be munching through VCV's though.
So there we go. https://www.instagram.com/hustynminepark/
Post #959406 24th Jul 2022 7:24pm
As Blackwolf suggested on here previously moisture in fuel can kill VCV’s. I know it was some poor fuel from a less well known fuel station that I had to use that finished mine off.
I had the original for many many years without fault, lacking top end power and having to overly accelerate is another symptom along with rough idle on the cold.
Just cutting out is another usually just when pulling off at a junction or stopping in the most dangerous places! ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #959416 24th Jul 2022 9:04pm
Bluericky
Yes seemingly always at a junction !
In fact it’s nearly always on occasions when one has been accelerating hard and then changes up a gear .
Presumably the VCV is unable to operate fast enough to compensate when worn.
Either way, I plan on keeping one in stock at all times in the “onboard essentials toolkit”, which is beginning to look quite substantial !! https://www.instagram.com/hustynminepark/
Post #959492 25th Jul 2022 5:48pm
Page 2 of 2 <12
