Home > Maintenance & Modifications > Battery Retainer thingamy
balmybaldwin
United Kingdom 2002 Defender 90 Td5 CSW Buckingham Blue
It seems my defender was supplied with a brand new but taller than standard battery.
As a result the retaining bar can't be extended enough to fit the battery.
Whilst it is wedged in quite well, I image in a big bump it could move. Is there a part number for longer retaining bars? or am I better off fitting a strap or something?
Perhaps there is an aftermarket solution?
Or is the answer just to get a less tall battery?
Post #947891 3rd Apr 2022 5:53pm
L110CDL
Could you get someone to extend the retaining bars, cut the metal and weld a new section in so that they will do the same job ? Clayton.
Keeper.
Post #948062 4th Apr 2022 9:18pm
Ratty43
Mine (non standard battery) is secured with a Halfords universal battery clamp, the bars each side are long enough that I had to cut them down before the cover could go back on.
Post #948063 4th Apr 2022 9:21pm
Mossberg
United Kingdom 1993 Defender 90 300 Tdi HT Aintree Green
I have a tall battery and using the original angled clamping bar would not allow enough thread to get the nuts on. I considered extending the hooks, but then they would interfere with the cover. I ended up replacing the angle bar with a piece of 50x5mm flatbar which I had hanging about. It allowed me to use the original screwed hooks.
Post #948076 4th Apr 2022 9:44pm
balmybaldwin
Thanks all... will get my thinking cap on
Post #948162 5th Apr 2022 12:40pm
