![]() | Home > Puma (Tdci) > Oil Cooler Thermostat yes or no? |
Disco_Mikey Member Since: 16 Nov 2014 Location: Dundee Posts: 532 ![]() ![]() ![]() |
2014MY, the oil cooler was changed and the thermostat removed
Whether its there or not, you won't have any issues, so long as it doesn't leak ![]() |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2422 ![]() ![]() |
See second post by dgardel in this topic https://www.defender2.net/forum/topic75153...oil+cooler
There are two replacement parts, one contains the thermostat elements, the other does not.
Dibble04 Member Since: 13 Feb 2022 Location: Devon Posts: 34 ![]() ![]() ![]() |
Understood...I read that thread earlier.
Why then do all the major parts suppliers sell the full thermostatic unit for the range of chassis numbers right up to 2016? I spoke with a Landrover mechanic today who said he always fits the fully functioning thermostat...it is for the reason that opinions vary that I raised a new topic on the subject. It simply isn't clear which way to go in my opinion but I would like it to be. |
Looking at the LRworkshop site diagrams with part numbers it shows that all 2.2’s have the thermostat housing without the thermostat parts fitted, ie just a pipe fitting. Part LR029936. So that covers 2012-2016.
So in part answer to your question, for a 2.2 it’s a no to an oil cooler thermostat. Also intriguing that a landrover mechanic would fit one with a thermostat to a 2.2 when it was not originally fitted when built at the factory. |
The mechanic was aware I have a 2.4 engine so it may be his answer would have been different if I asked about a 2.2.
Still none the wiser! |
itsdashy Member Since: 20 May 2021 Location: Reading Posts: 82 ![]() ![]() ![]() |
Probably something to do with them adding the variable pressure oil pump on the 2.2
