Home > In Car Electronics > OBD Security |
steveww Member Since: 05 Jan 2022 Location: Uppingham Posts: 537 |
I found this while surfing the net.
https://www.dummyobd.com/shop/relocation-land-rover/ I ordered on and it arrived promptly. It is well made and indeed the ODB port is exactly the same as on my 2015 Defender. Fitting it is a total faff of course because you're curled up in the footwell poking about behind the dash. You could take the whole dash out but I went with keyhole surgery. Taking out the top row of relays and sockets on the fuse board improves access. There's a bit of tape that needs to be snipped to free up the OBD loom. Where you put the live ODB port is up to you depending on how often you need access. |
19th Feb 2022 4:34pm |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 992 |
Interesting, thanks.
I'm also happy with this OBD lock: https://www.defender2.net/forum/topic53380.html?start=15 That's two layers then. |
20th Feb 2022 11:14am |
