![]() | Home > Maintenance & Modifications > Part number needed |
| bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248
Anybody got the part number for the plastic screw in expansion stud that holds the interior rear light covers in place on a 110 double cab ?
I have looked everywhere, including the linked parts list, and I can't find them. Thanks Bob |
Hi MK
In the double cab the rear lights are covered by a plastic cover in the tub. This is held in place by studs that have a plastic screw that expands the stud. Problem is that the screw head gives way before in can be removed. Bob |
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2509
I do not see it. I guess it is a special one, right? Puma 110" SW
Thanks MK - it must be double cab specific.
I will go to the stealers and get some ordered. Bob |
| mse Member Since: 06 Apr 2008 Location: UK Posts: 5117
Im sure you can pick them up in halfords - if they are the ones im thinking they are a common part...like a plastic rivet but the centre is a screw? Mike
| Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 339
It may be EYQ100130 Rivet-Plastic
It's in section D06.005 Body Electrics, In-car-entertainment IIRC the ones MSE refers to will just about fit, but are a slightly different size. |
Thanks Fifth Horseman - that is the one
That must be about the only section of MC I didn't look in Bob |
The same used in rear seats plastic trim cover (SW)
