Home > Maintenance & Modifications > Is hinge servicing an option?
Co1
My 90 is now 9 years old and all the hinge pins are starting to rust, is there no option at all to service them, as in knock the old pin out and replace (not sure about the rear though? If not, does anyone know of a replacement service that will colour match them (Loire blue) or is billet the way forward?
Post #947445 29th Mar 2022 7:29pm
Not really, it's well nigh impossible to get the pins out. Replacement is the cost-effective option.
Post #947456 29th Mar 2022 8:36pm
Co1
Thanks Blackwolf. Any tips out there on how to paint a set using rattle cans for longevity?
Post #947470 30th Mar 2022 5:59am
Vitesse
Hi. I use occasional acf50 treatment to my hinges and have done for 7 years since new. No evidence of rust or wear as yet. 78000 miles. I recommend this for your new hinges πŸ‘ 2015 90 XS Santorini Black
Post #947473 30th Mar 2022 6:50am
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
When I bought my 90 most of the rear door hinges were seizing up, over time and plenty of light oil two out of the three have freed off nicely, the third is better but still tight so I have bought a spare to change at some point as I’m told they are not serviceable Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #947477 30th Mar 2022 8:21am
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
I oil mine occasionally, maybe twice a year and this seems to work ok. Is this not as effective as the acf50?
The problem is that they are commonly just neglected until they are a problem and at that point it is too late.
Post #947480 30th Mar 2022 8:38am
Mo Murphy
Col, lubrication is a wonderful thing πŸ˜πŸ‘
50 Shades of Pennine Grey
Post #947483 30th Mar 2022 9:03am
Vitesse
Yes agreed. It has to be continuous really from new. I apply a little acf50 once month to all the hinges 2015 90 XS Santorini Black
Post #947484 30th Mar 2022 9:14am
J1990
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Tamar Blue
I'd be interested in people's thoughts on the approach taken here - For the cost of replacing with OEM hinges I'm not sure I'd bother with the pin replacement, but fitting the grease nipple intrigues me as an easy monthly job to take care of.
&t=349s&ab_channel=Defendermodsandtravels
Post #947486 30th Mar 2022 9:24am
Vitesse
Interesting solution. probably works very well at forcing moisture out etc and would no doubt increase the life of the hinge... But in my opinion is suited more where the vehicle might be heavily used off road frequently .. Just my thoughts... 2015 90 XS Santorini Black
Post #947529 30th Mar 2022 4:43pm
Co1
Mo
Mine are pretty regularly treated to ACF 50, but I fear that regularly using a foam degreaser to clean the car has negated the effect.
Grease nipples might be an option on a new set, but it’s not exactly subtle!
Post #947531 30th Mar 2022 4:48pm
Forum stalwart Landroveranorak on here had the excellent idea of drilling a small hole through the centre of the hinge from a discrete angle as far as the centre pin, which allows the hinge to be greased with a chainsaw-type push-action lubricator.
It's a really neat, subtle, and effective solution and one I'd definitely do if I ever had standard hinges again.
https://www.defender2.net/forum/post909912.html
https://www.defender2.net/forum/post707394.html
Post #947536 30th Mar 2022 5:45pm
Thanks for the mention. The idea was unashamedly pinched from another member, Lightningtweeds, though Laughing
Here's the direct link to my solution:
https://www.defender2.net/forum/post707394.html#707394 Darren
Post #947599 31st Mar 2022 9:57am
Shroppy
United Kingdom 1986 Defender 130 V8 Petrol HCPU Aintree Green
If you're replacing the hinges anyway, I'd definitely go down the security/billet route from optimill or similar. Or at the very least get some hinge plates. I don't see why you couldn't pain them to suit, though you might want to request them in raw instead of anodised. 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #947603 31st Mar 2022 10:54am
Co1
Thanks LRA. I’m going to have a crack at this on Saturday to see if I can catch them early enough. I really like the look of the original hinges, terribly security not withstanding!
Post #947640 31st Mar 2022 6:14pm
