Home > In Car Electronics > Quick help needed (before the shops shut :) ) |
Gasket Member Since: 30 May 2020 Location: Manchester Posts: 629 |
Might have answered this myself.
I think that a loom like this: https://www.ebay.co.uk/itm/181844936847?ep...Sw3ZpfnBRA would replace the loom I have and would connect straight from the head unit to the defender brown/grey looms. Is that right? |
27th Mar 2022 2:12pm |
matchap801 Member Since: 05 Aug 2021 Location: Somerset Posts: 120 |
Well done. That should do the job. Some Defenders had two standard ISO plugs in the loom, I believe Defenders are 2012 had a LR specific plug. So the trick was to get an adapter loom from the LR to stereo plug.
From memory when I upgraded mine, there weee two red wires. One per meant live (memory) one ignition live - turns the radio on / off with ignition. When first connected the radio wouldn’t work properly, so swapped them over and now works a treat! 2009 Defender 90 CSW 2.4 TDCI. Ex Army Mechanic still living the dream. |
27th Mar 2022 5:28pm |
Spot on - thank you.
Have one on order for delivery tomorrow. *Edit - arrived today and fitted perfect!* |
28th Mar 2022 12:11am |
