Home > Maintenance & Modifications > Teflon Tape on diff plugs
big110
 2014 Defender 110 Puma 2.2 SW Keswick Green
Have seen some folks do this, putting Teflon tape on the threads of the drain and fill plugs. Is this common or unnecessary?
Post #947149 26th Mar 2022 11:39pm
Ianh
The plugs are tapered so should not need ptfe tape, plus you don’t want bits of the tape coming off and getting in the diff, especially on removal. If you do feel the need for sealant then loctite 248 in a gel stick or hylomar blue works well. If removing diff plugs think of replacing both fill and drain with magnetic ones. They are not expensive and if you look at pics on line of them they seem to have a loctite 248 like thread sealant on them. I.e https://gwynlewis4x4.co.uk/product/magneti...ve-gl1160/
Post #947152 27th Mar 2022 1:52am
big110
Awesome that’s a great idea. Always curious what bits are coming off the gears especially with the ARB air lockers!
Post #947154 27th Mar 2022 2:17am
Mossberg
United Kingdom 1993 Defender 90 300 Tdi HT Aintree Green
I use tape on the plugs, though not sure if this is right or wrong. I know the plugs are a taper fit, so shouldn't need it, but I do it more as an antiseize than anything else.
I haven't really thought about the tape getting in the diff, but I do try to keep it away from the end. Ptfe tape is so soft I can't see it damaging gears, however if there are any oil ways then I suppose it could interfere with those if there was enough in it.
I have fitted the magnetic plugs but I can't comment on how good they are as I have not done a fluid change since fitting.
Post #947157 27th Mar 2022 4:57am
bear100
coming from the water industry i tend to use a sealing tape for tapered threads it helps seal them but also aids with removal stopping corrosion on the threads, Loctite 55 is well recommended Thumbs Up 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #947159 27th Mar 2022 7:24am
Screbble
I too use the smallest amount of PTFE tape.
Used to use it on large industrial motors and gearboxes when I was a apprentice - however that was a long time ago and knowledge and technology has advanced!
Post #947163 27th Mar 2022 8:52am
Dinnu
I also use a small amount of teflon tape. As with any other sealing material, there is always some risk of sealing material getting into the oil, but that will only happen if the plug is taken out, and the threads are not cleaned of the previous used sealing material before refitting the plug.
I actually prefer the teflon tape over some liquid thread sealing compounds as is far easier to clean the threads. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #947187 27th Mar 2022 2:55pm
Mo Murphy
I've never put anything on the diff plugs and I've never had any leaks from them.
50 Shades of Pennine Grey
Post #947192 27th Mar 2022 3:32pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Magnetic drain plugs do come with some sort of sealant; what is it? https://www.lrdirect.com/tyb500120-plug-drain
I also used a bit of teflon tape on the filler plugs. Just to make sure.
Post #947205 27th Mar 2022 6:02pm
miker
Funnily enough, mine is currently leaking lightly and I plan to put some teflon tape on it in an attempt to fix it!
Post #947211 27th Mar 2022 7:32pm
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
I use a light duty thread lock on all the drain plugs.
It doesn't lock it more than usually,but it makes an excellent thread sealant.
Post #947214 27th Mar 2022 8:06pm
jfh
Loctite 248 is maximum strength.
I use loctite 222 that is meant for small screws
Post #947215 27th Mar 2022 8:09pm
That Loctite 222 is good for many items, just enough without being any problem especially with small items.
Teflon tape, I do use it a small amount for the diff plugs. Never had the slightest issue with it.
I have a feeling there would be a weep from the drain plug, especially if I didn’t but as I said only a small amount I think no more than two winds of it. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #947216 27th Mar 2022 8:28pm
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
Never used it, shouldn't need it. If a tapered bung in an oil-filled unit is seizing up then it ain't getting taken out often enough, and if it leaks then there is a fault with it. ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #947491 30th Mar 2022 9:40am
miker
Leaking oil is indeed a common land rover fault.
Post #947559 30th Mar 2022 8:34pm
