Home > Puma (Tdci) > Where can I buy a replacement clip?
Doodlefish
There is a plastic retainer clip at the end of the small diameter air box induction hose. It snapped whilst I was replacing the hoses and now requires tape to hold it in place. Friction alone wont cut it. Knowing how sensitive the air flow system is I am keen to replace it. Any clues?
link is a pic showing location (red circle).
Post #947070 26th Mar 2022 9:44am
Doodlefish
Better photo - how do you add larger images?
Post #947071 26th Mar 2022 9:50am
Co1
I would think a jubilee clip will be plenty enough to hold it rather than tracking down a clip. I think it is the breather hose from the rocker cover, but it’s hard to tell from the pic!
Post #947073 26th Mar 2022 9:56am
Doodlefish
Thx Co1.
The jubilee wont work as its a male connection to the rocker cover. You have to jubilee clip the hose onto a rigid plastic 'transfer' connector then push in the grommet seal end of it into the hole at the rocker cover. The clip assembly comes as one piece with an 'over' collar retaining it in position. Its the over collar that has snapped.
https://www.defender2.net/gallery/albums/u...ition3.jpg
Post #947075 26th Mar 2022 10:02am
Gasket
Have you tried using the parts diagrams on the LRWorkshop site to find your clip?
https://www.lrworkshop.com/
Go to Menu/Diagrams/defender/
Then just start searching till you find it. If you create a free account you can enter your cars details so you’re only shown the relevant parts.
Post #947082 26th Mar 2022 11:19am
Co1
Censored me your engine bay is clean!!
Post #947107 26th Mar 2022 3:32pm
Doodlefish
Great idea Gasket....but its not there Big Cry
it should be a part where 12 is... Sad
Post #947114 26th Mar 2022 5:10pm
Doodlefish
Col1 - not my engine bay unfortunately Embarassed
I dont trust anyone with an engine bay that clean... Laughing
Post #947117 26th Mar 2022 5:12pm
Doodlefish
My engine bay
So you wont see the offending tape alternative Ive used beneath the rocker cover but you can just see the jubilee clip that fixes it to the part I need. The plastic element is seated ok into whatever hole its supposed to go to but there should be a flexible retaining collar I assume is to prevent it shooting off.
Post #947120 26th Mar 2022 5:27pm
Co1
Is it part of the rocker cover assembly instead?
Post #947134 26th Mar 2022 7:23pm
